Stealing/Reading Data from 16x2 LCD Display
Only related topic I found from 2011
I have a very similar application to the above thread. I have a piece of industrial equipment that displays an output to a 16x2 display. I would like to be able to read the text data so that I could do better logging and monitoring based on the messages it displays. I do know mine is also in 8 bit mode. I was wondering if anyone had figured out how to do this after 9 years.
My plan to approach this if there aren't any better suggestions will be to use their code at a higher multiple frequency to sample a string of data. Then parse it out to find where it repeats and from there separate it out into the 8 bit strings. If I can then convert the bits into the text I expect, I can then figure out how to "sync" the two devices using the rising or falling edge with probably some offset. That seems to be where the previous effort fell short.
Is the display a "standard" Hitachi 44780 type?
These have been around for years - there should be all sorts of sniffer software available.
Yeah, It's that type of display. Sniffer is the keyword I was missing. I've got a few more promising leads, Thanks!
