Steering Movement Problem
cutebuddy6: i have not grounded the 9th but the 8 is grounded
My bad - was reading your schematic wrong... :)
Still not seeing very much decoupling or common grounds.
if u can identify it with arrows or circle
dear this is the circuit thats completed and why its not working keen to know it
let me Explain you when it gets restarted/reset
when i say my steering to go Left it goes to left and when it starts to go left it restarts
and when its already left it doesnot restart
if i say it to go left and its turns the steering on left then its also get restarted
tell me please
here is the code that i am using
const int potPin = A0;
const int leftMotor = 10; //PWM pin to the L293
const int rightMotor = 9; //PWM pin to the L293
bool isLeft()          {
  return (analogRead(potPin)/4) < 14;
bool isLeftOfCenter()  {
  return (analogRead(potPin)/4) < 119;
bool isRightOfCenter() {
  return (analogRead(potPin)/4) > 133;
bool isRight()         {
  return (analogRead(potPin)/4) > 245;
void motorStop() {
  digitalWrite(leftMotor, LOW);
  digitalWrite(rightMotor, LOW);
void motorLeft() {
  digitalWrite(leftMotor, HIGH);
void motorRight() {
  digitalWrite(rightMotor, HIGH);
  Serial.println ("Entering setup.");
  if (Serial.available() == 0)
    return;
  switch (toupper(Serial.read()))
  case 'L':
    Serial.println("New command: L");
    if (isLeft())
      Serial.println("Already Left");
      Serial.println("Heading Left");
      motorLeft();
      while (!isLeft()) /* JUST WAITING */;
      motorStop();
      Serial.println("Is now Left");
  case 'C':
    Serial.println("New command: C");
    if (isRightOfCenter())
      Serial.println("Heading Left toward Center");
      motorLeft();
      while (isRightOfCenter()) /* JUST WAITING */;
      motorStop();
      Serial.println("Is now Centered");
      if (isLeftOfCenter())
        Serial.println("Heading Right toward Center");
        motorRight();
        while (isLeftOfCenter()) /* JUST WAITING */;
        motorStop();
        Serial.println("Already Centered");
  case 'R':
    Serial.println("New command: R");
    if (isRight())
      Serial.println("Already Right");
      Serial.println("Heading Right");
      motorRight();
      while (!isRight()) /* JUST WAITING */;
      motorStop();
      Serial.println("Is now Right");
  }  // end of switch on direction
}  // end of loop
Well, the code looks good (possibly because I wrote it for you).
What does the output on Serial Monitor look like?
well its get restarted after every two command or one command i send through serial monitor
i have Posted the schematic and what if i modify the code as
void setup() { Serial.begin(115200); Serial.println ("Entering setup."); pinMode(leftMotor, OUTPUT); pinMode(rightMotor, OUTPUT); }
cutebuddy6: -->What will RAM do when i am Moving the code
I've been sent a personal message by CuteBuddy6 to ask for more help. Please don't.
I don't understand this sort of talk. Are you asking what the RAM will do if the buggy moves?
Oh. I see we are up to page 4.
Almost certainly the program is restarting because of electrical issues. To test disconnect the buggy and see if it restarts. The circuit you posted doesn't seem (to me) to have the Arduino in it.
You seem to be completely incapable of responding to direct questions, such as:
johnwasser: What does the output on Serial Monitor look like?
cutebuddy6: well its get restarted after every two command or one command i send through serial monitor
How about replying?
What Do You See In The Serial Monitor????? Copy and Paste. Don't Just Describe It.
johnwasser:
Perhaps I should rephrase that. :frowning:
cutebuddy6, please start your sketch, start the Serial Monitor, try sending the commands L, R, C, R, L, C. Then copy all the text from the Serial Monitor window and paste it into a reply here.
New command: L Heading Left Is now Left New command: R Heading Right Is now Right New command: C Heading Left toward Center Is now Centered Entering setup. New command: L Heading Left Is now Left New command: R Heading Right Is now Right Entering setup. New command: C Heading Left toward Center Is now Centered New command: L Heading Left Is now Left New command: R Heading Right Is now Right Entering setup. New command: L Heading Left Is now Left New command: C Heading Right toward Center Is now Centered Entering setup.
here is what i get on serial Monitor
cutebuddy6: New command: L - Heading Left - Is now Left New command: R - Heading Right - Is now Right New command: C - Heading Left toward Center - Is now Centered Entering setup.
New command: L - Heading Left - Is now Left New command: R - Heading Right - Is now Right Entering setup.
New command: C - Heading Left toward Center - Is now Centered New command: L - Heading Left - Is now Left New command: R - Heading Right - Is now Right Entering setup.
New command: L - Heading Left - Is now Left New command: C - Heading Right toward Center - Is now Centered Entering setup.
So it has nothing to do with going Left specifically because it happens randomly after L, R, or C. It has nothing to do the motors running because it only happens AFTER the message that gets sent AFTER the motors have been stopped.
If it were a real Arduino there could be the possibility that the PC is glitching the DTR signal for some reason and the auto-reset is happening between commands. To test for that you could jumper the Reset pin to +5 and see if the symptom goes away. Since you have built your own Arduino-like circuit and have not shown it I don't know if you implemented auto-reset or not.
It just worked I followed the link given by the member and it just worked http://arduino.cc/forum/index.php/topic,91456.0.html
I'd like to refer you to reply #41
Thank you all of you in helping me out thanks
