I have to connect an Arduino mega to a PLC, and I will need the Arduino to run a sketch once it received a high signal from the Arduino. I am currently testing it on an UNO. I am just a little unsure of how to connect the step-down converter. Here is a link to the converter: https://www.amazon.com/gp/product/B00BWLP88A/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
MarkT:
level shifting a signal? If just a signal use a resistor divider.
Hi MarkT,
I have read in some articles that level shifting by a resistor divider is cheap but dirty. That means the signal will not be good and stable. How do you think?
Depends on the resistor values and the capacitance behind the level shifter.
If you feed the output of the level shifter into a length of twisted/shielded wire, you might end up with a low-pass filter.
Leo..
