Step Motor 28BYJ-48 ULN2003 Driver Board and UNO R3 Project Advice
Hello,
I have my step motor operating with a code that gives half rotation clockwise and then half rotation counter clockwise. I wonder if it is possible to programme for a narrower angle than 180 degrees movement, for example 90 degrees?
I'm using step motor: 28BYJ-48, ULN2003 driver board and UNO R3
Many thanks for any advice.
You need to post your program.
You can make a stepper motor move by as many or as few steps as you wish.
...R
Watch this YouTube video:
https://www.youtube.com/watch?v=0qwrnUeSpYQ&list=PLN0OZKrXk7Tp6WILmSXHjaBR2hJRyrZP9&index=60&t=0s
  #define STEPPER_PIN_1 9
  #define STEPPER_PIN_2 10
  #define STEPPER_PIN_3 11
  #define STEPPER_PIN_4 12
  int step_number = 0;
  pinMode(STEPPER_PIN_1, OUTPUT);
  pinMode(STEPPER_PIN_2, OUTPUT);
  pinMode(STEPPER_PIN_3, OUTPUT);
  pinMode(STEPPER_PIN_4, OUTPUT);
  for(int a = 0; a < 1000; a ++){
    OneStep(false);
    delay(2);
    OneStep(true);
    delay(2);
  void OneStep(bool dir){
    if(dir){
      switch(step_number){
      case 0:
      digitalWrite(STEPPER_PIN_1, HIGH);
      digitalWrite(STEPPER_PIN_2, LOW);
      digitalWrite(STEPPER_PIN_3, LOW);
      digitalWrite(STEPPER_PIN_4, LOW);
      case 1:
      digitalWrite(STEPPER_PIN_1, LOW);
      digitalWrite(STEPPER_PIN_2, HIGH);
      case 2:
      digitalWrite(STEPPER_PIN_3, HIGH);
      case 3:
      digitalWrite(STEPPER_PIN_4, HIGH);
      }else{
      case 0:
      case 1:
      case 2:
      case 3:
      step_number++;
      if(step_number > 3){
        step_number = 0;
Robin2:
…R
Robin2:
…R
In this piece of code
    OneStep(false);
    delay(2);
the number 1000 determines how many steps are taken and the number 2 determines how fast the motor moves.
This would be more obvious if variables with meaningful names are used in place of the “magic” numbers - for example
  for(int a = 0; a < numberOfSteps; a ++){
    OneStep(false);
    delay(intervalBetweenSteps);
And at the top of the program you could define the variables as
int numberOfSteps = 1000;  // or whatever number you want
int intervalBetweenSteps = 2;
…R
Thank you for your reply. How would I adapt my code to narrow the degree of revolution from a half revolution to a quarter revolution?
Tell us what this does:
jarjam:
I had hoped you would be able to figure that out from what I wrote in Reply #4
…R
1 rev for a 28BYJ-48 is 2048 full steps, 512 for a quarter rev.
Try experimenting.
Change 1000 to 500 etc.
for(int a = 0; a < 500; a ++)
larryd:
Perfect! Thank you for help and speedy replys, much appreciated.
