I wrote a small and simple S-shaped envelop stepper movement sketch. It’s still early, but it seems to work fine.
I wanted something simple that could protect stepper and gearbox mechanisms from wear and tear.
It’s not that sophisticated, but instead it’s made so that user-can tune it.
You only need the last functions; the first two are for testing.
Make sure you don’t have heavy, fast and dangerous equipment hooked up for testing.
(In other words, use at your own risk.)
Edit: Had older version with int’s for Acceleration/Deceleration; these were changed to Floats.
It had been failing over 90 steps on Acceleration/Deceleration.
// For testing
const int pin_step = 13;
void setup ()
pinMode (pin_step, OUTPUT);
step_s (pin_step, 8000, 8000, 30000, 30, 10, 10);
void step_s (int pin_step, int pulsewidth, int pulsewait_min, float pulsewait_max, int steps_total, float steps_attack, float steps_decay)
// Sends Timed Pulses for Stepper S-Curved Accelleration / Deceleration
// Version 1.004
// By Brenda Make
// pin_step = Pin to send pulses to.
// pulsewidth = Duration of pulse to sent.
// pulsewait_min = Shortest Pulse to use for fastest speed, in microseconds.
// pulsewait_max = Longest Pulse to use for slowest speed, in microseconds.
// steps_total = Total length of movement in steps or pulses.
// steps_attack = Attack portion of movement.
// steps_decay = Decay portion of movement.
// Steps_attack and steps_decay should be even numbers over 6.
// The sustain length must be at least 1.
int count, wait, scale;
float steps, angle, rad;
// For a Quarter Wave
steps = 90 / steps_attack;
scale = (pulsewait_max - pulsewait_min) / 2;
// Attack First Quadrant
for ( angle = 270 ; angle < 360 ; angle = angle + steps )
rad = angle / 360 * 6.283185307;
wait = abs (int ( sin (rad) * (scale) ) );
wait = wait + scale + pulsewait_min;
pulse (pin_step, pulsewidth, wait);
// Attack Second Quadrant
for ( angle = 0 ; angle < 90 ; angle = angle + steps )
wait = scale - wait;
wait = wait + pulsewait_min;
// Sustain
steps = steps_total - (steps_attack, steps_decay);
for ( count = 0 ; count < steps ; count++ )
pulse (pin_step, pulsewidth, pulsewait_min);
steps = 90 / steps_decay;
// Decay First Quadrant
for ( angle = 90 ; angle < 180 ; angle = angle + steps )
// Decay Second Quadrant
for ( angle = 180 ; angle < 270 ; angle = angle + steps )
void pulse (int pin_step, int pulsewidth, int wait)
// Pulse
digitalWrite (pin_step, HIGH);
delayMicroseconds (pulsewidth);
digitalWrite (pin_step, LOW);
// Wait
delayMicroseconds (wait);
