Hey guys, I'm working on a new project where I am building a fermentation chamber for making beer.
I was hoping someone had a suggestions as to how I can use two buttons to adjust a target temperature variable. I would basically like to kick on a fan when above a target temperature and in the future I will attach a relay and turn on a heat mat if below the target temperature. I've attached the code below and I will have 2 buttons and a LCD monitor. When the program starts it will start by creating a targetTemp variable at 68 degrees. Then I would like to have two buttons (one to increase and one to decrease the targetTemp). I tried putting together what I thought would work, but it is not actually changing the target temp. Any help you could provide would be great.
Thanks,
Craig
// Kegerator Temperature Monitor
// Included libraries
#include <OneWire.h> // For DS18b20 temp sensor
#include <DallasTemperature.h> // Simplifies reading of temp
#include <Wire.h> // Communicate with I2C / TWI devices
#include <LiquidCrystal_I2C.h> // For SainSmart IIC/I2C/TWI Serial 2004 LCD
LiquidCrystal_I2C lcd(0x27,20,4); // Sets LCD to 20 Columns by 4 Rows
#define tempSensor 2 // Temperature sensor is plugged into pin 2 on the Arduino
OneWire oneWire(tempSensor); // Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire); // Pass oneWire reference to Dallas Temperature.
const int FanPin = 11; // Fan pin
const int buttonUp = 7; // Up Button pin
const int buttonDown = 6; // Down Button pin
int targetTemp = 68; // Define a target temp when Arduino resets
void setup(void)
lcd.init(); // initialize the lcd
lcd.backlight();
sensors.begin(); // turn on sensors for DS18b20
pinMode(buttonUp, INPUT); // Set INCREASE button to input
pinMode(buttonDown, INPUT); // Set DECREASE button to input
pinMode(FanPin, OUTPUT); // Set Fan motor to output
lcd.setCursor(0,0); // Set LCD cursor to first cursor spot
lcd.print("Temperature"); // Print "Temperature" to cursor spot on LCD
void loop(void)
sensors.requestTemperatures(); // Get temperature readings
lcd.setCursor(2,1);
lcd.print(sensors.getTempFByIndex(0)); // Print actual temperature
// Write to Serial for Testing
Serial.println("Actual Temperature");
Serial.println(sensors.getTempFByIndex(0));
// Increase target temp
if (buttonUp == HIGH) {
targetTemp = ++targetTemp; // If button is pushed, move Target Temp up by 1
// Decrease target temp
if (buttonDown == HIGH) {
targetTemp = --targetTemp; // If button is pushed, move Target Temp down by 1
Serial.println("Target Temperature");
Serial.println(targetTemp);
// Cooling Element
// Turn on Fan if temp is below target temperature
if (sensors.getTempFByIndex(0) > targetTemp) {
analogWrite(FanPin, 255);
analogWrite(FanPin, 0);
Thanks for the quick response. I am not sure what you meant about the solar system quote, but I'm guessing that you're inferring that there is something fundamentally wrong with my code. I believe that the buttons are wired correctly as I used one of the Arduino tutorials using a pullup resistor, but my guess is that the code is incorrect.
My goal was to read if the buttonUp is pressed, then to increase the targetTemp. Do I need to make it say digitalRead(buttonUp)?
Thanks for the help. Also, if there is a different way which you'd recommend doing this, I am all for suggestions. I just tried to make up how I thought it should work.
Paul, let me know if you think this should fix it. I probably did forget the digitalRead...
void setup(void)
lcd.backlight();
void loop(void)
lcd.setCursor(2,1);
if (digitalRead(buttonUp) == HIGH) {
if (digitalRead(buttonDown) == HIGH) {
// Cooling Element
This is undefined behavior. Use one of:
targetTemp = targetTemp + 1;
targetTemp += 1;
targetTemp++;
else {
Useless.
You already got the temperature when you wanted to print it. Do it ONCE. Save the value in a variable. Print the variable's contents. Compare the variable's value in this if statement.
