Step Up problems with Sim900A
I can't believe, some mouths ago i tested my system with atmega328 and Sim900A with a MT3608 Step Up.
I got 3.7 to 5v and all went right with different battery.
Today i've been tested the same system but i find that the MT3608 can't supply the right current(I think) to the Sim900a that go down on start.
I tried that with different battery with the same result.
I know that:
  1. Sim900A need to 2A peak to start
  2. If i use a usb power supply 1.5A system start without problem and the sim9000A starts.
Sorry for my english.
Thank's
Have you checked what your MT3608 is outputting?
Both voltage and current?
GSM transceivers require a good solid 2A peak current from its supply, and takes those peaks only during
transmit timeslices (normally 1 in 8 slices). I suggest adding a lot more decoupling (1000uF or so) and you
might protect the DC-DC converter from the pulse loading that's likely tripping it out.
Thanks, i tried to do it, but i used two ceramic and i don't remember values.
This evening i'm going to check with two 1000uf electrolytic capacitors like you suggest.
I'll let you know.
Thanks.
Hi MarkT,
You don't know how you helped me, now it works with two 1000uf capacitors
Thank's.
Even if i knew the problem, i tried with different capacitor and probably I would have spent much time for other tests.
Thank's a lot.
