Stepper delay code help
hello everyone,
I am trying to create a code for a stepper motor that will stop for 10 seconds and then continue turning the stepper motor. i am using a external driver for a nema 17 stepper and an external power supply. please see a excerpt from my code below. Essentially I want to create a square wave
if (psi > 5099) { // initialize pressure, assuming pressure is high at the start of test
    stepper.step(-100);
  else if (psi == 5100) { // high pressure delay
   delay(10000); // stop for 10 second
   stepper.step(-100) // after delay continue to turn stepper
  else if (psi == 3100) { // lower limit delay
    stepper.step(100); // reverse direction to bring pressure back up to 5100 psi
And.... what is it doing vs. what you expect it to do? Snippets of code are useless. Post the entire sketch as outlined in the sticky post at the top of the forum. It helps people help you.
In the case where your psi value is 5100 your first "if" is true and that is where your block of code will end. The "if psi == 5100" is unreachable.
Hello
And why you don“t do so?
i see, i have fixed that now. I want the program to stop once the pressure hits 5100 psi for 10 seconds and then continue to move the stepper. Right now with the code, it stops and moves the stepper every 10 seconds. is there a better way to make that stepper move constantly after the 10 seconds wait.
How do you expect that else to EVER be true? If psi == 5100, the if WILL be true, so the else will never be reached.
If the psi value remains at 5100, then that if statement that creates the 10 second delay will continue to be true.
You need another condition, for example a boolean that you set to true on the first time you run the delay, integrate that with the if condition. e.g:
if( psi == 5100 ){
 if(  ! alreadyDelayed ){
  delay(10000);
  alreadyDelayed =true;
stepper.step(-100);
when i add that to my code i do not get the desired wait. Please let me know if i did this right.
include <Stepper.h> // include the stepper library.
#define STEPS 200 // number of steps for one rotation.
Stepper stepper(STEPS, 5, 3); // define the steps, pin 5 is direction, and pin 3 is the steps.
#define motorInterfaceType 1 // defines the case for the stepper library, this one is the external driver.
float psi; // define the variable for psi as a conversion.
int T1 = A0; // transducer is connected to the anolog 0 pin.
int volt; // initialize the voltage variable.
bool alreadyDelayed;
  Serial.begin(9600); // setup the serial monitor read and write rate.
  stepper.setSpeed(800); // set the speed for the rotation RPM.
  pinMode(T1, INPUT); // sets T1 as in input.
  volt = analogRead(T1); // set voltage to the value at T1.
  Serial.print("T1: "); // Prints T1:
  Serial.println(volt); // prints the value of T1
  //delay(10); //wait for half a second.
  psi = (9.77 * (analogRead(T1))) + (0); // converts the voltage value to PSI.
  // y=mx+b where m is slope (transducer reading (0-10000)/voltage read (0-1023)) + b (offset)
  Serial.print("PSI: "); // Prints PSI:
  Serial.println(psi); // Prints the value of psi
  //delay(10); // wait for half a second.
  if (psi > 5109) { // initialize pressure, assuming pressure is high at the start of test
    stepper.step(-5); // clockwise
    if (! alreadyDelayed){
      delay(10000);
      alreadyDelayed = true;
   stepper.step(-5); // after delay continue to turn stepper
    delay(10000); // stop for 5 second
    stepper.step(5); // reverse direction to bring pressure back up to 5100 psi
It might just be that you need to intialise "alreadyDelayed" to false to start. Either that or change the check to "alreadyDelayed != true". I'm fairly new to Arduino so take my guidance as broad strokes.
i do expect that to be true because the stepper will open a valve reliving pressure to bring the pressure down. so this will indeed change the state of psi.
The first else - "else if (psi == 5100)" - will NEVER be executed. What you expect will NOT happen.
If you reverse them, perhaps it will do what you expect.
When you are dealing with floating point numbers like psi, you will never hit exactly 5100 or 3100. You need to be testing for >= or <=. It was not clear to me if the stepper moves once to open/close something or if it should move multiple times to increase/decrease the opening. This code assumes it only moves once
#include <Stepper.h> // include the stepper library.
const int T1 = A0; // transducer is connected to the anolog 0 pin.
const unsigned long waitTime = 10000;
const float maxPressure = 5100.0;
const float minPressure = 3100.0;
enum { GOING_UP, GOING_DOWN };
int state = GOING_UP;
unsigned long startTime;
  // figure out where to start
  if ( readPressure() < maxPressure ) {
    stepper.step(5);
    state = GOING_UP;
  else {
    stepper.step(-5);
    state = GOING_DOWN;
  float psi = readPressure();
  if ( state == GOING_UP ) {
    // pressure is going up
    if (psi >= maxPressure) {
      // we have reached max, pressure, wait and go back down
      delay(waitTime);
      state = GOING_DOWN;
      stepper.step(-5);
  else {
    // pressure is going down
    if (psi <= minPressure) {
      delay(waitTime);
      state = GOING_UP;
      stepper.step(5);
float readPressure() {
  int volt = analogRead(T1); // set voltage to the value at T1.
  float psi = (9.77 * volt) + (0); // converts the voltage value to PSI.
  return psi;
