stepper driver reprap diode option
hello guys
can someone help me about this (reprap driver 1.2) problem. can i change the original design diode (SB360) with diode (1N5822) why i change? because the SB360 diode is really hard to find.
this SB360 datasheet http://www.vishay.com/docs/88719/88719.pdf
and this for 1N5822 http://www.vishay.com/docs/88526/88526.pdf
(sorry for my english)
thanks Ali
What is the application?
for control the stepper motor, and conect 3 of them to arduino for make DIY cnc here is the line of reprap stepper driver 1.2 http://reprap.org/wiki/Stepper_Motor_Driver_1_2
What will you be using for the motor supply voltage?
SB360 =60 volts 1N5822=40 volts
If the motor voltage is 30 Volts or less I would use it.
yes, the motor about 12 volt,
thanks larry :D
