This is my first Post:
This project was originally to learn about how to wire up the stepper motor driver.
Hardware:
Once I got the basics of speed control, changed the code to get the motor to follow the POT, (full sweep of the pot, translates to 1 rotation of the stepper motor).
Long story short I spent a couple of days trying all sorts of methods to stop the motor vibrating ( this only happens when the pot is in the middle of range of motion).
I used some some timing code, although timing microseconds worked in a trial sketch as soon as I implemented it within the main program the Serial.println() function was so slow and timings were no use at all. Im using a arduino UNO R3 have been programing it for about 3 days I am completely new to this.
I attempted to use arrays to store sensor and Average results as a buffer.
int array[10]; basically made the program non responsive. When I made the array size 5 or less the program functioned but didnt help with the noise. I dont really understand how array of size [10] broke the machine. I was not even utilizing it in the code. Was just in declared variables.
I have 2 main questions:
Given the current hardware im using how would you filter the POT while still maintaining some responsiveness?
Secondly:
There seems to be hundreds of options regarding hardware. If I wanted to do software based filtering more maths and algorithms focused while having some real world feedback. What would you recomend?
// Stepper Follows Pot - Arduino Uno R3
//Hardware Pins
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
const int stepPin = 3;
const int dirPin = 5;
//State Variables
int sensorValue1 = 0; // 0-1023 potentiometer
int sensorValue2 = 0; // 2 vars to calc change
int sensorChange = 0; //
int pulsePerRev = 20000; // Pulses Per Revolution 40_000
int pulseCount = 0; // Absolute position within 1 revolution
int pulseControlCount = 0; //Change during control step postive OR negative
int counter = 0;
int i = 0;
int j = 0;
int k = 0;
unsigned int stepDelay = 3; // Controls Velocity of Motor
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
digitalWrite(stepPin, HIGH);
pulseCount = 0;
j = j + 1;
k = k + 1;
//Update State:
if(j= 5)
sensorValue2 = analogRead(analogInPin); // Raw sensor value.
sensorChange = sensorValue2 - sensorValue1;
sensorValue1 = sensorValue2;
j = 0;
if(sensorValue1 == 0)
pulseCount = 0;
//Decision Step: what will we do with latests state information?
pulseControlCount = abs(map(sensorChange, 0, 511, 0, pulsePerRev));
//Do Step: Control stepper motor
if(k= 1000)
delayMicroseconds(10);
if(sensorChange > 0)
digitalWrite(dirPin, LOW);
for(i=1; i<pulseControlCount; i++)
delayMicroseconds(stepDelay);
digitalWrite(stepPin, LOW);
pulseCount = pulseCount + pulseControlCount;
if(sensorChange <=0)
digitalWrite(dirPin, HIGH);
for (i=1; i<pulseControlCount; i++)
pulseCount = pulseCount - pulseControlCount;
k = 0;
Thanks for you help. There were so many versions of the code I ended up with what you see. I cleared out as much variables and junk. I ended up with what you see here.
