Ive recently been testing and driving some new steppers I got with the standard arduino Stepper Library, I am aware that a few bugs have been posted about this perticular Library.
If this bug has already been posted and reported my apologies but I was unable to find it in the forums and its still in the most recent release
During my test with the stepper i used a potentiometer to set the speed of the stepper,
I have a 45v powersupply @ 3A, so I know the voltage isnt the problem
and my Stepper is 1.8deg/step with total 200 steps/revolution
Here's the code I started with:
Stepper stepper(200,5,6,7,8);
del = map(analogRead(0),0,1024,1,500);
stepper.setSpeed(del)
stepper.step(1);
This is suppose to map out the 0-1023 value from the analog pin to 0-500 for the rpm of the stepper library
While moving the knob through its full rotation I noticed the stepper reach a certain speed and any further the stepper stop moving and generated a semi high frequency,
I pulled out my osciliscope and noticed as I turned the knob the frequency on 1 of the 4 pins jumped from 245hz to 6000hz
This striked me as odd so i went back to the code and found that this happened when I set the setSpeed() function to 301, anything before 300 would be fine but 301+ generated alarming high frequency,
I looked through the Stepper Library code and found the problem and also came up with a solution
Heres the section of code that has the bug, where the delay is setup for the step function
void Stepper::setSpeed(long whatSpeed)
this->step_delay = 60L * 1000L / this->number_of_steps / whatSpeed;
void Stepper::step(int steps_to_move)
if (millis() - this->last_step_time >= this->step_delay)
this->last_step_time = millis();
in the setSpeed function it calculates the delay needed in milliseconds to achive the deisred switching frequency. It appears that the step_delay variable which is apparently an int-type variable freaks out when I use 301+ rpm @ 200 steps/revolution
heres why:
60 * 1000 / #ofsteps / speed
= 60 * 1000 / 200 / 301
= 60,000 / 200 / 301
= 300/301
=0.9966
due to the int-type variable the 0.996 dosnt work to well, becuase it uses that value and the millis() function to determin the delay
FIXED
by using the micros() function instead of the millis() function and multiplying the step_delay by 1000 it maps the 0.996 millisecond delay to 996 microsecond delay, because 1 millisecond = 1000 microseconds
CODE:
this->step_delay = 60L * 1000L / this->number_of_steps * 1000 / whatSpeed;
if (micros() - this->last_step_time >= this->step_delay)
this->last_step_time = micros();
This has been checked with an osciliscope and the 6000hz frequency that was being generated at 301rpm @ 200steps is now around 250hz, where as the 300rpm value that worked with the bug was around 245hz
PROBLEM FIXED!!
enjoy
Arch3r
