Stepper Libray fails due to math.h error
I've been using the standard stepper library as supplied as part of arduino 0022 and have come back to some code that was working previously but that now will not compile - the error seems to be related to the math.h library but I am uncertain as to why this error suddenly occured as the library was working previously.
I'm trying to drive a stepper using the library and not doing anything too unusual I think.
Any advice much appreciated...
I'm using a Macbook Pro with OS x 10.5.8 and Duemilanove
The code is copied below and the error is:
In file included from /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/WProgram.h:6,
from stepper_library_test.cpp:4:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/math.h:439: error: expected unqualified-id before 'double'
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/math.h:439: error: expected )' before 'double' /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/include/math.h:439: error: expected )' before 'double'
#include <Stepper.h>
Stepper bigstepper (200, 4,6,5,7); // 200 step stepper 1.8deg
// note the pin order is not normal
// 4 red, 5 green, 6 black, 7 yellow
// for R S191 - 8356 Motor
//bigstepper.setSpeed(6); // 6 RPM
bigstepper.setSpeed(6); // 6 rpm
bigstepper.step(200); //no of steps
delay (500);
bigstepper.setSpeed(25); //25 rpm
bigstepper.step(-200); // no of steps backwards
delay (200);
I think that some of the macros defined in 'wiring.h', such as round,abs,... etc. are now part of math.h in later versions of avr-libc.
That conflicts of course. It should help to delete the now useless parts of wiring.h
(found this thread because of a similar problem)
(part of the ) solution is in this thread - http://arduino.cc/forum/index.php/topic,71405.0.html - read carefully.
