Stepper Motor Control - one revolution <<<<<<<<<<<<<<<<<<<<< Modified
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
//const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
// Stepper myStepper(stepsPerRevolution, 8,9,10,11);
Stepper myStepper(stepsPerRevolution, 11,9,10,8); // <<<<<<<<<<< Note 8 & 11 swapped
// set the speed at 60 rpm:
myStepper.setSpeed(120);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
for (int x=1;x<12;x++)
myStepper.step(stepsPerRevolution);
Serial.println(x);
// step one revolution in the other direction:
Serial.println("counterclockwise");
for (int x =1;x<12;x++)
myStepper.step(-stepsPerRevolution);
Serial.println(x);
hi guys,
i had the same problem as buster009 and i tried LarryD's posted code.
the shaft turns when clockwise code executed but in counterclockwise part it starts trembling and the shaft remains still.
is there any posibility of the step motor to have problem or something else migh cause that? any ideas plz would be apreciated.
p.s. sorry for my english, i know they are not that good.
