Hi guys, I quite new in ARduino, but I'm working on a Motorized Slider with arduino to shoot some videos, but now that i have the Potenstiometer I'm stuck in this code; here is my hardware setup:
with a code like this the motor goes perfectly with the standard delayLenght of 30:
int delaylegnth = 30;
//establish motor direction toggle pins
pinMode(12, OUTPUT); //CH A -- HIGH = forwards and LOW = backwards???
pinMode(13, OUTPUT); //CH B -- HIGH = forwards and LOW = backwards???
//establish motor brake pins
pinMode(9, OUTPUT); //brake (disable) CH A
pinMode(8, OUTPUT); //brake (disable) CH B
void loop(){
digitalWrite(9, LOW); //ENABLE CH A
digitalWrite(8, HIGH); //DISABLE CH B
digitalWrite(12, HIGH); //Sets direction of CH A
analogWrite(3, 255); //Moves CH A
delay(delaylegnth);
digitalWrite(9, HIGH); //DISABLE CH A
digitalWrite(8, LOW); //ENABLE CH B
digitalWrite(13, LOW); //Sets direction of CH B
analogWrite(11, 255); //Moves CH B
delay(delaylegnth);
digitalWrite(12, LOW); //Sets direction of CH A
delay(delaylegnth);
digitalWrite(13, HIGH); //Sets direction of CH B
delay(delaylegnth);
so I tried to add 2 Potentiometer, one to set the speed with delayLenght, and the other to set the direction of rotation.
as you can see from the code, I want to take the value from pot in A3 and divide the value by 30 to set a better delay. prendo il valore e lo divido per 30 perchè ho bisogno di una tolleranza nel scegliere il delay.
The other Pot in A2 set the direction, in fact if it is <= di 513 it makes run the code that spin CCW if it's > CW.
HERE IS MY CODE:
int analogPin = 3; //collego il potenziometro della velocità a pin A3
int analogPin2 = 2; //collegoil potenziometro della direzione a pin A2
int analread = analogRead(analogPin/30);
int analread2 = analogRead(analogPin2);
int delaylegnth = analread;
int rotazione = analread2;
//sketch completato SLIDER MOTORIZZATO arduino
void loop(){
if (rotazione <= 511) // va a dx se rotazione ==100
delay(delaylegnth);
delay(delaylegnth);
delay(delaylegnth);
delay(delaylegnth);
if (rotazione > 511) // va a sx se rotazione ==0
delay(delaylegnth);
delay(delaylegnth);
delay(delaylegnth);
delay(delaylegnth);
If I connect everything as it should all the leds of Motorshield stay ON and the motor makes a whistle.
If I turn o disconnect the pot nothing happend.
Please Help me
