Hello everybody! I am trying to make a force feedback wheel and I am almost done! I am using a stepper motor, and I know that it's not the right choice for a ffb wheel, and a better dc motor is coming soon, but for now I want to take some measurements and test it. When I give the stepper motor a specific speed it does work, but when I replace it with a variable it just doesn't rotate and not the serial monitor nor the game detects and potentiometer movement. It doesn't take any more data from the potentiometer. I've been trying to troubleshoot this myself for the past 10 days and I just cannot get it to work, and when I tell you I tried everything I knew I mean it. Nothing worked.
Here is the code:
#include <Stepper.h>
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 4, 5, 6, 7);
long value1 = 0;
int value = 0;
#include "Joystick.h"
//X-axis & Y-axis REQUIRED
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_GAMEPAD, //JOYSTICK, GAMEPAD, MULTI_AXIS
4, 0, //Button Count, Hat Switch Count
true, true, true, //X,Y,Z
true, false, false, //Rx,Ry,Rz
false, false, true, //Rudder,Throttle,Accelerator
false, true); //Brake,Steering
Gains mygains[3];
EffectParams myeffectparams[3];
int32_t forces[3] = { 0 };
pinMode(A5, INPUT);
pinMode(13, OUTPUT);
pinMode(7, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(4, OUTPUT);
pinMode(A5, INPUT);
//Joystick.setXAxisRange(0, 1023);
//Steering wheel
Joystick.setZAxisRange(0, 1023);
//set X Axis gains
mygains[0].totalGain = 90; //0-100
mygains[0].springGain = 90;
//enable gains REQUIRED
Joystick.setGains(mygains);
Joystick.begin();
digitalWrite(13, HIGH);
myeffectparams[0].springMaxPosition = 1023;
myeffectparams[0].springPosition = analogRead(A5); //-512-512
Joystick.setEffectParams(myeffectparams);
Joystick.getForce(forces);
Joystick.setXAxis(analogRead(A5));
value = abs(forces[0]);
value1 = map(value,0,255,0,160);
if(forces[0] > 0) {
myStepper.setSpeed(value1);
myStepper.step(1);
}else if(forces[0] < 0){
myStepper.step(-1);
}else{
long value1 = map(value,0,255,0,160);
myStepper.step(1);
Serial.println(analogRead(A5));
delay(1);
I know that this code is an absolute mess and I know that there is a lot of unnecessary stuff like the beginning of the loop ,but I've tried everything. I tried to cover it for every case scenario.
