Hi Andreas,
well, here is a second try. I used some more classes of MobaTools. Setting the zero point by a 3 second press is implemented, but the modes have to be added. I'm not sure about the 400 degree angle limit. Is it 400 degrees in both directions or 400 degrees in total? But you can simply adjust that by changing the '400' to '200'.
I hope this fits better to your needs. Now it's your turn ![]()
regards
Franz-Peter
#include <MobaTools.h>
// hardware related definitiona
// Set pins according to your hardware
// ( button and enable was set to the same pin in your first attempt )
const int stepPin = 6; //3;
const int dirPin = 5; //4;
const int enPin = 7; //2;
const byte buttonPins[] = {2};
const byte joyLRPin = A1;
const int ledPin = LED_BUILTIN;
const long maxAngle = 400; // this is the max angle in every direction.
const int maxSpeed = 2500; // max Speed is 2500 steps/sec ( depends what the motor can do )
const int minSpeed = 10; // lowest Speed
const int stepsPerRev = 200 * 50; // steps per revolution with gear box
// limits for joystick
const int joyLimits[] = { 245, 500, 524, 774 };
//const int joyLimits[] = { 0, 500, 524, 1024 };
int joyLR;
int joyLRmap;
int motorSpeed = 500; // Steps/sec
// create MobaTools objects
MoToStepper stepper1( stepsPerRev, STEPDIR ); // create a stepper instance
MoToButtons myButtons( buttonPins, 1, 20, 3000 ); // manage buttons(s), longpress is 3 seconds
MoToTimebase printTimer; // Timer to print in regular intervals without blocking sketch
MoToTimebase joyTimer; // Timer to read joystick in regular intervals without blocking sketch
Serial.begin (115200);
printTimer.setBasetime( 1000 ); // print values every second
joyTimer.setBasetime( 100 ); // read joystick 10 times a second
pinMode(ledPin, OUTPUT);
// initiate stepper
stepper1.attach( stepPin, dirPin );
stepper1.setSpeed(motorSpeed ); // rev/min (if stepsPerRev is set correctly)
stepper1.setRampLen( 100 ); // set ramp length to what the motor needs to not loose steps
stepper1.attachEnable( enPin, 100, LOW ); // disable motor current in standstill
myButtons.processButtons();
if (joyTimer.tick() ) {
// read joystick and set stepper speed accordingly
joyLR = analogRead(joyLRPin);
// if the joystic is in the middle ===> sti
if ( joyLR > joyLimits[1] && joyLR < joyLimits[2] ) // neutral area
digitalWrite(ledPin, HIGH);
stepper1.rotate(0 ); // stop stepper if joystick in the middle
{ // move the motor in desired direction
digitalWrite(ledPin, LOW);
if ( joyLR >= joyLimits[2] ) {
// move towards max angle
motorSpeed = map ( joyLR , joyLimits[2], joyLimits[3] , minSpeed, maxSpeed ); // Values may be adjusted to the joystick
stepper1.setSpeedSteps( motorSpeed * 10 );
stepper1.write( maxAngle );
// move towards min angle
motorSpeed = map ( joyLR , joyLimits[1], joyLimits[0] , minSpeed, maxSpeed ); // Values may be adjusted to the joystick
stepper1.write( -maxAngle );
if ( myButtons.longPress(0) ) {
// button pressed long -> set referencepoint
Serial.println( "Set referencepoint" );
stepper1.setZero();
if ( printTimer.tick() ) {
// debug printing every second
Serial.print( "CurrentAngle "); Serial.print(stepper1.read() );
Serial.print ( " step "); Serial.print (stepper1.readSteps() );
Serial.print ( " DIR ");
if (joyLR >= joyLimits[2]) Serial.print ( "right") ;
else if (joyLR <= joyLimits[1]) Serial.print( "left");
else Serial.print( "stop");
Serial.print ( " SpeedCC "); Serial.print (motorSpeed);
Serial.print(" joyLR = "); Serial.print (joyLR);
Serial.print(" Button= "); Serial.println (myButtons.state(0));
