Hi all,
I have a fairly simple task and worked quite a bit on it, but not successful, so I figured I'll try my luck here. I have a nema stepper with 1.8°/step attached to an adafruit shield (v2 I think) and an arduino (uno). The motor is supposed to move fwd or bkwd depending on the sign of the number I input and possibly the fastest possible way, so if in = 345°- > in = - 15° or vice versa if in = -190° -> in = 170°. Does anyone see an obvious mistake, the motor moves only in one direction?
Thx in advance.
This is a test sketch for the Adafruit assembled Motor Shield for Arduino v2
It won't work with v1.x motor shields! Only for the v2's with built in PWM
control
For use with the Adafruit Motor Shield v2
----> http://www.adafruit.com/products/1438
#include <Wire.h>
#include <Adafruit_MotorShield.h>
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Stepper test!");
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
myMotor->setSpeed(10); // 10 rpm
int i = 0;
int i2 = 0;
int i3 = 0;
int i4 = 0;
int result = 0;
int steps = 0;
int sign = 1;
int result = 0;
i2= 0;
sign = 1;
while (Serial.available() > 0)
i = Serial.read();
if ((i >= 48)&&(i <=57))
i = i-48;
result = result*10+i;
Serial.print("I received: ");
Serial.println(result, DEC);
i2 = 1;
else if (i == 45)
{sign = -1;}
delay(50);
if (result <0)
result = 0;
i = 0;
if (i2 == 1)
{ while (result > 360) // only single rotations
{result = result - 360}
if((result > 180) && (sign ==-1)) // e.g. -190° = 170° -> faster
{result = result + 360;}
else if ((result > 180) && (sign == 1)) // e.g. 210° = -150° -> faster
{result = result - 360;}
{result = result;}
result = result*sign;
result = result/1.8; //conversion from degree to step
steps = result;
if(steps == 0)
Serial.print("won't move");
if (steps > 0)
//Serial.println(steps, DEC);
Serial.print('forward');
myMotor->step(steps, FORWARD, MICROSTEP);
steps = steps *(-1);
Serial.print('backward');
myMotor->step(steps, BACKWARD, MICROSTEP);
