stepper motor + beamsensor
Hi, I used arduino before to control a stepper motor by using ULN2003 circuit(http://electronics-diy.com/electronics/stepper_motors.php) as the driver of my stepper motor.
I am trying to build a small conveyor (Length : 300mm x Width : 130mm), which rotates for a designated distance(for about 100mm) every time a beam sensor is disturbed.
So, I figured that this kind of simple process can be done by other controllers that are way cheaper than arduino.
Definitely arduino is much better to work with but I also would like to try it out with cheapter method for a simple process like this.
My question is (1) can I use arduino development environment to program other controllers?
(2) In order to use a beam sensor with this stepper motor driver circuit(http://electronics-diy.com/electronics/stepper_motors.php), how should I connect the sensor to this circuit(or to controller circuit)?
My stepper motor has a specification like this.
*Voltage *Current *Resistance *Inductance *Holding torque
4.0V 0.95A 4.2Ohm 3.3mH 1.6kgf.cm
Any word of advice from you would be very helpful to me.
Thank you.
You can program the chip on the arduino to do what you need and then move it to a "carrier board" that can cost as little as $5 and use that in your circuit. As for the sensor you could hook it to one of the interrupt pins to generate an interrupt when it is triggered.
so, I can use arduino's developement environment to program other chips. That's great.
Could you tell me what type of chips and carrier boards are available for my specific application?
