My drive circuits are exactly as per the examples show on the Stepper library page Stepper - Arduino Reference
4-pins used in both circuits.
I wasn't expecting much difference in the torque with these two configurations, but there is a HUGE difference. The bipolar works fine while the unipolar has very little torque, if I touch it lightly with my fingers it stops.
A unipolar will generally provide less torque than a bipolar since it only uses half of a winding when driven in unipolar mode. You don't have to drive your unipolar motor in unipolar mode -- just treat it like a bipolar motor and drive it using the "outside" winding terminals. The holding torque for the unipolar motor was probably specified as a "salesmanship number", i.e., as large as possible, when driving the motor using the full winding (bipolar mode).
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
Thanks, thats helpful. The only issue I have with running the 12v unipolar in bipolar mode is that I won't be able to get the full rated current (torque) at 12v because of the extra resistance from using the whole coil... I guess there is no way around that short of increasing the voltage?
