Stepper Motor Button Code
Hey everyone, I have the code below which is used to turn a stepper motor in forward or reverse a certain number of steps depending on which of the two buttons is pushed. To activate forward or reverse, the button must be pressed and released. Is there a simple way to change this code so that the motor will continue to turn in forward or reverse for as long as the button is pressed? This is opposed to just turned the defined number of steps per the code. If anyone has any similar code to reference that would be much appreciated. Thanks!
// defines pins numbers
const int dirPin  = 3;
const int stepPin = 4;
const int enPin   = 5;
const int switchOne     = 8;
const int switchTwo     = 9;
int p1buttonState = 0;         // current state of the button
int lastp1buttonState = 0;     // previous state of the button
int p2buttonState = 0;         // current state of the button
int lastp2buttonState = 0;     // previous state of the button
bool bPress = false;
bool isForward = false;
bool isBackward = false;
  pinMode( switchOne, INPUT_PULLUP);
  pinMode( switchTwo, INPUT_PULLUP);
  // Sets the two pins as Outputs
  pinMode(stepPin, OUTPUT);
  pinMode(dirPin, OUTPUT);
  pinMode(enPin, OUTPUT);
  digitalWrite(enPin, LOW);
  isForward = false;
  isBackward = false;
  p1buttonState = digitalRead(switchOne);
  p2buttonState = digitalRead(switchTwo);
  if (p1ButtonPress()) {
    digitalWrite(dirPin, HIGH);
    delay(5);
  if (p2ButtonPress()) {
    digitalWrite(dirPin, LOW);
    delay(5);
  if ( isForward || isBackward ) {
    for (int x = 0; x < 2000; x++) { //2000 = 360 degrees at 400pulse/rev
      digitalWrite(stepPin, HIGH);
      delayMicroseconds(500); //sets speed
      digitalWrite(stepPin, LOW);
bool p1ButtonPress()
  bool isPress = false;
  // compare the p1buttonState to its previous state
  if (p1buttonState != lastp1buttonState) {
    // if the state has changed, increment the counter
    if (p1buttonState == LOW) {
      // if the current state is HIGH then the button went from off to on:
      bPress = true;
      isPress = true;
      Serial.println("Plaer One score");
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
      isForward = true;
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastp1buttonState = p1buttonState;
  return isPress;
bool p2ButtonPress()
  if (p2buttonState != lastp2buttonState) {
    if (p2buttonState == LOW) {
      bPress = true;
      isPress = true;
      Serial.println("Plaer Two score");
      isBackward = true;
    delay(50);
  lastp2buttonState = p2buttonState;
  return isPress;
In the Arduino IDE, use Ctrl T or CMD T to format your code then copy the complete sketch. Use the </> icon from the ‘posting menu’ to attach the copied sketch.
Always show us a good schematic of your proposed circuit. Show us a good image of your ‘actual’ wiring. Give links to components.
You mean while the switch is pressed ?
Yes, use the Bounce2 library which does all the work to handle your buttons (there are examples). Then, you can continuously check for .isPressed() and take another step in the appropriate direction. The library will make it very easy.
This part of your sketch makes the motor move one revolution:
Maybe try:
   // for (int x = 0; x < 2000; x++) { //2000 = 360 degrees at 400pulse/rev
     while (!p1buttonState || !p2buttonState) // !pxbuttonState is "pressed"
No, don't try that. That would be an infinite loop since you never update your button state variables.
You need to read your buttons inside the loop.
Oops. I see my mistake. Thank you.
