Hii Everyone,
This is Eliyas,
Can you help to write a code to move forward & backward to integrated the 9 wire printhead using bipolar stepper motor with help of Arduino uno board.
Thanks in advanced
Hii Everyone,
This is Eliyas,
Thanks in advanced
Yes.
We need some additional information.
Post your sketch, well formated, with well-tempered comments and in so called code tags "< code >" and a detailed circuit diagram to see how we can help.
In this we are using
note:- Below i am attaching the project specifications pls check it.
drv8811.pdf (2.2 MB)
This will work with a TI DRV8811:
https://www.airspayce.com/mikem/arduino/AccelStepper/Bounce_8pde-example.html
// Bounce.pde
// -*- mode: C++ -*-
// Make a single stepper bounce from one limit to another
// Copyright (C) 2012 Mike McCauley
// $Id: Random.pde,v 1.1 2011/01/05 01:51:01 mikem Exp mikem $
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper; // Defaults to AccelStepper::FULL4WIRE (4 pins) on 2, 3, 4, 5
// Change these to suit your stepper if you want
stepper.setMaxSpeed(100);
stepper.setAcceleration(20);
stepper.moveTo(500);
// If at the end of travel go to the other end
if (stepper.distanceToGo() == 0)
stepper.moveTo(-stepper.currentPosition());
stepper.run();
...but you need to modify it to use the driver config rather than the 4-wire config:
