/STEPPER MOTOR CODE ©2011 bildr
I put together the stepper arduino and code and get an error message after 1 time pulse…
The simultor says that there is a negative vaue returned wich is not allowed.
\I added the coede and a screen shot of the error message ( at the botom of the pic in dutch )
//STEPPER MOTOR CODE ©2011 bildr
//Released under the MIT License - Please reuse change and share
//Using the easy stepper with your arduino
//use rotate and/or rotateDeg to controll stepper motor
//speed is any number from .01 → 1 with 1 being fastest -
//Slower Speed == Stronger movement
//©2017 Travis Antoniello
//Released under the MIT License - Please reuse change and share. Incorporates code from a 2011 Bildr release also under MIT License.
//Uses the easy stepper to rotate a stepper motor turntable and an IR LED to trigger a NIKON D3200 DSLR. Pulse can be modified to trigger your camera.
//Serial commands: 0-ABORT, 1-START SCAN SEQUENCE, 2-10 DEGREES CW, 3-10 DEGREES CCW, 4-TRIGGER CAMERA
//Scan sequence will capture image then rotate. Captures 36 frames, one per 10 degree rotation. Status LED will blink for each IR trigger.
//Abort sequence can be called during the scan sequence. This will return turntable to original position.
#define DIR_PIN 2 // Direction pin on Easy Driver
#define STEP_PIN 3 // Step pin on Easy Driver
#define STATUS_PIN 5 // Status LED flash to identify current operations
#define IR_PIN 6 // Infrared LED used to trigger camera
int input; // Serial input placeholder
int turnsToReverse = 0; // Used by the abort function to return turntable to original position
int msWaitAfterPictureTaken = 2000; // How long in ms to wait after triggering camera - may need to be adjusted based on shutter speed.
int msWaitAfterRotation = 1000; // How long in ms to wait after rotating the turntable - may need to be adjusted if the object wobbles.
bool standby = true; // Enters standby mode if true
pinMode(DIR_PIN, OUTPUT);
pinMode(STEP_PIN, OUTPUT);
pinMode(STATUS_PIN, OUTPUT);
pinMode(IR_PIN, OUTPUT);
Serial.println(“Entering standby mode”);
void loop(){
standbySequence();
if(Serial.available() > 0)
input = Serial.read();
switch(input)
case 0 + 48:
Serial.println(“Abort sequence initiated.”);
abortSequence(turnsToReverse);
Serial.println(“Abort sequence completed.”);
standby = true;
case 1 + 48:
Serial.println(“Starting scan sequence.”);
scanSequence();
Serial.println(“Scan sequence completed.”);
case 2 + 48:
Serial.println(“DEBUG: 10 DEG CW”);
rotateDeg(10, .01);
case 3 + 48:
Serial.println(“DEBUG: 10 DEG CCW”);
rotateDeg(-10, .01);
case 4 + 48:
Serial.println(“DEBUG: TRIGGER CAMERA”);
triggerCamera();
default:
Serial.println(“ERROR: Unknown value!”);
void rotate(int steps, float speed){
//rotate a specific number of microsteps (8 microsteps per step) - (negitive for reverse movement)
//speed is any number from .01 → 1 with 1 being fastest - Slower is stronger
int dir = (steps > 0)? HIGH:LOW;
steps = abs(steps);
digitalWrite(DIR_PIN,dir);
float usDelay = (1/speed) * 70;
for(int i=0; i < steps; i++){
digitalWrite(STEP_PIN, HIGH);
delayMicroseconds(usDelay);
digitalWrite(STEP_PIN, LOW);
void rotateDeg(float deg, float speed){
//rotate a specific number of degrees (negitive for reverse movement)
int dir = (deg > 0)? HIGH:LOW;
int steps = abs(deg)*(1/0.225);
void standbySequence()
while(standby && Serial.available() == 0)
digitalWrite(STATUS_PIN, HIGH);
digitalWrite(STATUS_PIN, LOW);
void triggerCamera()
int count = 0;
while(count < 3) {
tone(IR_PIN,38000);
delay(2);
noTone(IR_PIN);
delay(28);
tone(IR_PIN,38000);
delayMicroseconds(200);
noTone(IR_PIN);
delayMicroseconds(1500);
tone(IR_PIN,38000);
noTone(IR_PIN);
delayMicroseconds(3300);
tone(IR_PIN,38000);
noTone(IR_PIN);
delayMicroseconds(100);
delay(63);
count++;
delay(50);
delay(100);
delay(50);
delay(100);
void abortSequence(int turns)
if(standby == false && turns <= 18)
Serial.println(“Resetting position.”);
Serial.print(“Reversing “); Serial.print(turns); Serial.println(” turns.”);
rotateDeg(-(10*turns), .01);
turnsToReverse = 0;
standby = true;
else if(standby == false && turns > 18)
rotateDeg(((36 - turns) * 10), .01);
turnsToReverse = 0;
standby = true;
void scanSequence()
standby = false;
for(int i = 0; i < 36; i++)
if(Serial.available() == 0 && standby == false)
Serial.print("Capturing frame: "); Serial.println(i+1);
triggerCamera();
delay(msWaitAfterPictureTaken); // Delay after triggering camera
rotateDeg(10, .01);
delay(msWaitAfterRotation); // Delay after rotating, for object to settle
turnsToReverse = i + 1;
To make it easy for people to help you please modify your post and use the code button </>
so your code
looks like this
and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor. The text editor shows line numbers, identifies matching brackets and allows me to search for things like all instances of a particular variable or function.
Also please use the AutoFormat tool to indent your code consistently for easier reading.
...R
RichardRoel:
The simulator says that there is a negative value returned which is not allowed.
I added the code and a screen shot of the error message ( at the bottom of the pic in dutch )
I think the problem is in the ‘simulator’ since it seems to behave fine on an Arduino UNO with Serial Monitor set to “No line ending” and 9600 Baud.
Note: If you have line endings turned on the “Scan sequence” will complete immediately because of the line ending character(s) in the input buffer. You may want to allow for this by using Serial.peek() to see if there is ‘\n’ or ‘\r’ in the buffer and toss them.
  for (int i = 0; i < 36; i++)
    // Gobble any line endings in the input buffer before checking for available input
    while (Serial.available())
      char nextChar = Serial.peek();
      if (nextChar != '\n' && nextChar != '\r')
        break;  // Valid input character.  Exit the while() loop.
      Serial.read();  // Throw out the line ending character
    if (Serial.available() == 0 && standby == false)
On reset:
On entering ‘0’:
On entering ‘1’:
Capturing frame: 1
Capturing frame: 2
Capturing frame: 3
Capturing frame: 4
Capturing frame: 33
Capturing frame: 34
Capturing frame: 35
Capturing frame: 36
On entering ‘2’:
DEBUG: 10 DEG CW
On entering ‘3’:
DEBUG: 10 DEG CCW
On entering ‘4’:
On entering ‘5’:
