Stepper motor code doesn't compile
const int dirPin = 8;
const int stepPin = 9;
const int steps = 200;
int microPausa = 1000;
pinMode(dirPin, OUTPUT);
pinMode(stepPin, OUTPUT);
 digitalWrite(dirPin, HIGH);  // Establezco una dirección
 for (int i = 0; i < steps; steps ; i++) {
   digitalWrite(stepPin, HIGH);
   delayMicroseconds(microPausa);
   digitalWrite(stepPin, LOW);
 digitalWrite(dirPin, LOW);  // Cambio la dirección
Compilation error: expected ')' before ';' token
You need to review your for loop syntax.
Also please change the topic title; it is misleading.
Fix the various program errors, and perhaps the stepper will work!
Welcome to the forum
    for (int i = 0; i < steps; steps; i++)
Look carefully at the parameters in the for loop initialisation
Why is the second use of the steps variable there ?
Also, where is the } at the end of the loop() function ?
Yes it was so I changed it.
Thanks
