im a newbie with arduino can any body help
code:
#include <AccelStepper.h>
// motor pins
Preformatted text
#define motorPin1 4 // Blue - 28BYJ-48 pin 1
#define motorPin2 5 // Pink - 28BYJ-48 pin 2
#define motorPin3 6 // Yellow - 28BYJ-48 pin 3
#define motorPin4 7 // Orange - 28BYJ-48 pin 4
// Red - 28BYJ-48 pin 5 (VCC)
// Blue - 28BYJ-48 pin GND
#define STEPS_PER_TURN 2048 // number of steps in 360deg;
int motorSpeed = 500; // High speeds (800 and above) may cause erratic behavior in 28BYJ-48
int motorAccel = 400; // As above: better avoiding extreme accelerations
int myPos = 0; // will be used to define a starting point for 360deg; rotations
int LeftTurnUp = 0; // Couple of flags to determine rotation direction
int RightTurnDown = 0; // Couple of flags to determine rotation direction
int Continuous = 0; // used below to discriminate single rotation commands
int incomingByte = 0; // for incoming serial data
/-----( Objects for stepper control )-----/
// Set up the stepper as 4 wire bipolar on pin 4,5,6,7
// NOTE: The sequence 1-3-2-4 is required for proper sequencing of 28BYJ48
AccelStepper stepper(4,motorPin1,motorPin3,motorPin2,motorPin4);
stepper.setMinPulseWidth(20); // Advisable setting to avoid that pulses from Arduino
// are too quick to be decoded
stepper.setMaxSpeed(motorSpeed);
stepper.setSpeed(motorSpeed);
stepper.setAcceleration(motorAccel);
// the following two lines reset "step zero" to the current position
stepper.setCurrentPosition(stepper.currentPosition());
stepper.runToPosition();
Serial.println("Available commands:");
Serial.println("R = continuous clockwise rotation");
Serial.println("r = 360deg; clockwise rotation");
Serial.println("L = continuous counter-clockwise rotation");
Serial.println("l = 360deg; counter-clockwise rotation");
Serial.println("S = stop rotation");
if (Serial.available() > 0)
incomingByte = Serial.read();
if (incomingByte == 'R')
Serial.println("received «R» - activating continuous clockwise rotation");
// The two lines that follow allow to send commands in any sequence:
// before execution, a quick stop is performed
stepper.stop(); // Stop as fast as possible: sets new target
stepper.runToPosition(); // Now stopped after quickstop
// The following couple of flags determines rotation direction
LeftTurnUp = 1;
RightTurnDown = 0;
Continuous = 1; // used below to discriminate single rotation commands
stepper.setCurrentPosition(stepper.currentPosition()); // Set step 0 "here"
stepper.setSpeed(motorSpeed); // Previous commands have reset the speed
if (incomingByte == 'L')
Serial.println("received «L» - activating continuous counter-clockwise rotation");
RightTurnDown = 1;
LeftTurnUp = 0;
if (incomingByte == 'r')
Serial.println("received «r» - activating single clockwise rotation");
LeftTurnUp = 1;
RightTurnDown = 0;
// Since I will have to step forward 2047 steps, I store my current
// position as starting point of the rotation
myPos=stepper.currentPosition();
if (incomingByte == 'l')
Serial.println("received «l» - activating single counter-clockwise rotation");
RightTurnDown = 1;
LeftTurnUp = 0;
// Since I will have to step backwards 2047 steps, I store my current
if (incomingByte == 'S')
Serial.println("received «S» - stopping rotation");
// Reset the flags that determine rotation direction
LeftTurnUp = 0;
RightTurnDown = 0;
if (Continuous == 1) // continuous rotation
if (LeftTurnUp == 1) //left turn
stepper.moveTo(10000); //move many steps - more then mechanically needed
if (RightTurnDown == 1) //right turn
stepper.moveTo(-10000); //move many steps - more then mechanically needed
stepper.run();
if (Continuous == 0) // continuous rotation
stepper.moveTo(myPos+STEPS_PER_TURN); // 1 turn = 2048 step
stepper.moveTo(myPos-STEPS_PER_TURN); // 1 turn = 2048 step
stepper.run();
