Hello everyone, I am fairly new to arduino. I am trying to make my stepper motor move a 1/2 turn when I press on button and a full turn when i press another. If I write just the code for one button it works, but if I add the coding for the other button the stepper vibrates constantly and wont move. What am I doing wrong?
I plan on eventually incorporating 4 buttons to do 1/4, 1/2, 3/4 and a full turn.
//Stepper Driver for table saw fence V.1
#include <Stepper.h> // Include stepper library
#define STEPS 2038 // Number of steps per revolution (28BYJ-48)stepper
Stepper stepper(STEPS, 8, 9, 10, 11); // name of stepper, number of steps and pins
int pushButton = 3; // Push button on pin 3
int pushButton2 = 4; // Push button on pin 4
pinMode(pushButton, INPUT); // push button is an input
pinMode(pushButton2, INPUT);
stepper.setSpeed(10); // sets speed of stepper to 10
int buttonState = digitalRead(pushButton); // assign variable to button
if (buttonState == 1)
stepper.step(1019); // if button is pressed turn 1/2 rotation and stop
int buttonState2 = digitalRead(pushButton2);
if (buttonState2 == 1)
stepper.step(2038);
delay(1000); //delay to allow time for spin and release of buttons
I have pull Down resistors connected to the buttons. I will Try The INPUT_PULLUP and see if that makes a difference.
Do i need to tell it what to do when no button is pressed? does it just default to doing nothing?
The stepper should be wired correctly. When i uploaded a test program made for the stepper and stepper controller it worked just like it was supposed to.
else if (buttonState2 == 1)
stepper.step(2038);
Got it to work! Ended up using a variety of what you guys said to make this code,
pinMode(pushButton, INPUT_PULLUP); // push button is an input pull up (High when not presses)
pinMode(pushButton2, INPUT_PULLUP); // push button is an input pull up
if (buttonState == LOW)
else if (buttonState2 == LOW)
stepper.step(2038);
