I have been following this tutorial on how to connect a PS3 controller to my arduino uno via a USB host shield. The tutorial takes you only as far as printing the PS3 buttons pressed on the serial monitor (which it now does) but now I want to put it to good use. I want to control a car which operates via two stepper motors but I'm unsure how to do it. My code from the tutorial is below and I just want to make it so when either the joystick is moved, the stepper motors move accordingly.
#include <PS3BT.h>
USB Usb;
BTD Btd(&Usb); // You have to create the Bluetooth Dongle instance like so
/* You can create the instance of the class in two ways */
PS3BT PS3(&Btd); // This will just create the instance
//PS3BT PS3(&Btd,0x00,0x15,0x83,0x3D,0x0A,0x57); // This will also store the bluetooth address - this can be obtained from the dongle when running the sketch
boolean printTemperature;
boolean printAngle;
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start"));
while(1); //halt
Serial.print(F("\r\nPS3 Bluetooth Library Started"));
Usb.Task();
if(PS3.PS3Connected || PS3.PS3NavigationConnected) {
if(PS3.getAnalogHat(LeftHatX) > 137 || PS3.getAnalogHat(LeftHatX) < 117 || PS3.getAnalogHat(LeftHatY) > 137 || PS3.getAnalogHat(LeftHatY) < 117 || PS3.getAnalogHat(RightHatX) > 137 || PS3.getAnalogHat(RightHatX) < 117 || PS3.getAnalogHat(RightHatY) > 137 || PS3.getAnalogHat(RightHatY) < 117) {
Serial.print(F("\r\nLeftHatX: "));
Serial.print(PS3.getAnalogHat(LeftHatX));
Serial.print(F("\tLeftHatY: "));
Serial.print(PS3.getAnalogHat(LeftHatY));
Serial.print(F("\tRightHatX: "));
Serial.print(PS3.getAnalogHat(RightHatX));
Serial.print(F("\tRightHatY: "));
Serial.print(PS3.getAnalogHat(RightHatY));
//Analog button values can be read from almost all buttons
if(PS3.getAnalogButton(L2_ANALOG) > 0 || PS3.getAnalogButton(R2_ANALOG) > 0) {
Serial.print(F("\r\nL2: "));
Serial.print(PS3.getAnalogButton(L2_ANALOG));
Serial.print(F("\tR2: "));
Serial.print(PS3.getAnalogButton(R2_ANALOG));
if(PS3.getButtonClick(PS)) {
Serial.print(F("\r\nPS"));
PS3.disconnect();
else {
if(PS3.getButtonClick(TRIANGLE))
Serial.print(F("\r\nTraingle"));
if(PS3.getButtonClick(CIRCLE))
Serial.print(F("\r\nCircle"));
if(PS3.getButtonClick(CROSS))
Serial.print(F("\r\nCross"));
if(PS3.getButtonClick(SQUARE))
Serial.print(F("\r\nSquare"));
if(PS3.getButtonClick(UP)) {
Serial.print(F("\r\nUp"));
if(PS3.PS3Connected) {
PS3.setAllOff();
PS3.setLedOn(LED4);
if(PS3.getButtonClick(RIGHT)) {
Serial.print(F("\r\nRight"));
PS3.setAllOff();
PS3.setLedOn(LED1);
if(PS3.getButtonClick(DOWN)) {
Serial.print(F("\r\nDown"));
PS3.setAllOff();
PS3.setLedOn(LED2);
if(PS3.getButtonClick(LEFT)) {
Serial.print(F("\r\nLeft"));
PS3.setAllOff();
PS3.setLedOn(LED3);
I am using an easy driver module ( Easy Driver Examples ) to operate the steppers. The joy stick has analog values (0-255) and I want to make use of the AccelStepper library to increase the speed of the steppers accordingly. Can anyone help? I am very new to all of this. Cheers
Links to tutorial and USB Host Shield Library are below.
Tutorial: How to Connect a PS3 controller to an Arduino with a USB host shield and Bluetooth dongle (Part 1) - YouTube
USB Host Library: GitHub - felis/USB_Host_Shield_2.0: Revision 2.0 of USB Host Library for Arduino.
I've also attached the relevant files that are used for my code.
PS3BT.cpp (27.8 KB)
PS3BT.h (6.29 KB)
