Robin2:
Write a program that makes proper use of the stepper library. If it does not work then post a copy of YOUR code explaining what it actually does.
Post a link to the datasheet for your motor.
What motor power supply are you using (volts and amps) ?
…R
Stepper Motor Basics
Two_Steppers.ino Arduining.com 30 MAY 2015
Driving two steppers concurrently with the Arduino Nano.
stepperX follows potentiometer on analog input 0.
stepperY follows potentiometer on analog input 1.
A timeout is used to turn off coils and save energy in battery
operated applications.
Hardware:
Arduino NANO.
Drivers: ULN2003A
Stepper Motors: 28BYJ48, 5VDC, step angle 5.625 °
Gear reduction 64:1
No-load starting frequency:> = 500PPS (4 rpm)
Coil resistance 60 Ohms.
#include <Stepper.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int potpin = 2; // analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
#define STEPSREV 4096 // 64(fullsteps) * 64 (reduction ratio)
#define SPEED 4 // motor speed (RPM)
#define COIL_1X 8
#define COIL_2X 9
#define COIL_3X 10
#define COIL_4X 11
#define COIL_1Y 7
#define COIL_2Y 5
#define COIL_3Y 6
#define COIL_4Y 4
#define POT_X 0
#define POT_Y 1
#define TIMEOUT 1000 //Turns off after 1 sec of inactivity.
#define NOISE 8 //inmunity in steps because analog noisy readings.
// create the instances of the stepper class.
Stepper stepperX(STEPSREV, COIL_1X, COIL_2X, COIL_3X, COIL_4X);
Stepper stepperY(STEPSREV, COIL_1Y, COIL_2Y, COIL_3Y, COIL_4Y);
int potValX,potValY; // potentiometers analog readings
int Xpos,Ypos; // Actual steppers positions(0-4096)->(0-360°)
int newXpos, newYpos; // New steppers positions
unsigned long stampX, stampY; // last move time stamped.
//============== functions ====================================================
//Read the potentiometers and map the reading to mach 360 degrees.
void readPots(){
potValX = analogRead(POT_X); // read POT_X value (0-1023).
potValY = analogRead(POT_Y); // read POT_Y value (0-1023).
newXpos= map(potValX,0,1023,0,2047); // Map pot X range to one stepper turn.
newYpos= map(potValY,0,1023,0,2047); // Map pot Y range to the stepper turn.
// Aproach stepperX to the newX position.
void aproachX(int newX){
int Xdir = Xpos<newX ? 1 : -1;
stepperX.step(Xdir); // move one step in the Xdir direction.
Xpos += Xdir; // update Xpos.
stampX = millis(); // stamp actual time.
// Aproach stepperY to the newY position.
void aproachY(int newY){
int Ydir = Ypos<newY ? 1 : -1;
stepperY.step(Ydir); // move one step in the Ydir direction.
Ypos += Ydir; // update Ypos.
stampY = millis(); // stamp actual time.
//Check for inactivity and turn off the steppers coils to save battery.
void CheckTimeout(){
if((millis() - stampX) > TIMEOUT){ //Turn Off StepperX coils.
digitalWrite(COIL_1X, LOW);
digitalWrite(COIL_2X, LOW);
digitalWrite(COIL_3X, LOW);
digitalWrite(COIL_4X, LOW);
if((millis() - stampY) > TIMEOUT){ //Turn Off StepperY coils.
digitalWrite(COIL_1Y, LOW);
digitalWrite(COIL_2Y, LOW);
digitalWrite(COIL_3Y, LOW);
digitalWrite(COIL_4Y, LOW);
//=================== setup ===================================================
void setup(){
stepperX.setSpeed(SPEED); // set the X motor speed.
stepperY.setSpeed(SPEED); // set the Y motor speed.
readPots();
Xpos = newXpos;
Ypos = newYpos;
myservo.attach(29); // attaches the servo on pin 9 to the servo object
//================= main loop =================================================
void loop(){
readPots();
//if diference is greater than NOISE move steppers.
if(abs(newXpos - Xpos)> NOISE) aproachX(newXpos);
if(abs(newYpos - Ypos)> NOISE) aproachY(newYpos);
CheckTimeout(); //check for inactivity.
val = analogRead(potpin); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
I modified it a little this morning after I found out what I did wrong I changed how my small Y access stepper was firing the coils work fine now so I was trying to add servos to the sketch not sure if I doing it right because as I wrote I am new to this and still learning also the nema 17 stepper is a 48oz/in stepper running from a L298n driver dual H bridge from a PC power supply 5v 25amp as is all servos will be and the small stepper motor I will try to get some 9pin joystick moduals from ebay as there cheap and will work better then turning knobs to move the steppers and servos when I get all the code and things work because I am making a robot head to move with me so when I tell story’s to the sick kids in our hospital it will move as if it is telling the story some day to add arms and such thank you for your help
