Dear Arduino-ers,
It's my first post here - I did use the search, but wasn't lucky:
Right now I'm trying to control a Stepper Motor in a very basic way, it's a QMOT Stepper hooked
up to a schmalzhaus easy driver, that I control using a Arduino Mega.
To do this, I wanted to to write an own method that I would call from the loop() method:
pinMode(3, OUTPUT); // Direction of turning
pinMode(2, OUTPUT); // Microsteps
turnMotor(8000, 115, 1, 3, 2); // Calling my own method to turn 8000 steps with 115 speed, direction right, on pins 3 for direction and 2 for stepping
// Microsteps-Maximum 8000 when I call it from another method. If I use any more steps than 8000, the motor won't turn at all.
// Delay time minimum 115 microseconds
// 1 = Right, 0 = Left
/*for (int i = 0; i<160000; i++) // 1600 = one Turn. When I leave this loop right inside the void loop() method, the Motor will turn for 160 000 steps just fine!
digitalWrite(2, LOW);
digitalWrite(2, HIGH);
delayMicroseconds(115);
void turnMotor(int microsteps, int turnspeed, int leftright, int dirpin, int steppin){
/* Serial.println("Turning for: " + microsteps); // This is another thing that won't work. The Serial won't print any of the variables ...
Serial.println("Turnspeed: " + turnspeed);
Serial.println("Direction: " + leftright); // and it does only print the strings (without any integer vars showing) until this portion here
Serial.println("On Pins (direction): " + dirpin);
Serial.println("and (step): " + steppin);
if(leftright==0){
digitalWrite(dirpin, LOW);
}else{
digitalWrite(dirpin, HIGH);
for (int i = 0; i<microsteps; i++)
digitalWrite(steppin, LOW);
digitalWrite(steppin, HIGH);
delayMicroseconds(turnspeed); // Minimum Delay Time - 115 Microseconds für den QMOT Schrittmotor
My problem is, that if I call the for-loop out of the void loop() method, it can go up to almost unlimited microsteps
(that are defined by how often the for-loop loops and creates the PWM signal)
HOWEVER: When I use my void turnMotor method, if I enter any variable higher than 8000, the motor will just not
move at all.
It really drives me crazy: Why can I loop the for-loop as often as I want inside of the void loop() method,
but why won't it loop that often if I tell my own method to do so, why will it just stop moving the motor?
Is there a limit in Arduino regarding the size/length of an Integer that you can use as a var. inside your own method?
I'd be happy for any help,
Regards,
- Max
