Stepper motor does not turn anticlockwise
Hi, I am using nema 17 and TB6560 driver. I am trying to run the motor in clockwise and anti-clockwise direction. but the motor just keeps running in clockwise direction even when the stepsize given is negative. please help.
this is the code
AccelStepper stepper1(AccelStepper::DRIVER, STEPPER1_STEP_PIN, STEPPER1_DIR_PIN);
int stepsize1;
  Serial.println("start");
  if (stepper1.distanceToGo() == 0)
    stepsize1 = 200; // or -200
    stepper1.setMaxSpeed(1000);
    stepper1.moveTo(stepsize1);
    stepper1.setSpeed(106);
  stepper1.runSpeed();
You should take a look at the documentation of AccelStepper :wink:
using moveTo / setMaxSpeed together with setSpeed/runSpeed does not make sense.
if you want to position the stepper with moveTo use only setMaxSpeed and run instead of runSpeed.
Thank you so much that brought a lot of clarity.
