Can any one advise which stepper motor driver to use for controlling 3 NEMA 17 stepper motors?
I used a L298N but it gets too hot after a while.
thanks
Phase Number: 2
I'd also suggest you use a stepper driver - one that's rated for the current of your steppers.
Or if you insist on using an H-bridge for his, at least use a halfway modern one instead of the old L298N, and make sure you have a means of limiting the current in the motor coils.
That are the two main specifications. The first tells it's a regular bipolar motor, the second how much current you want to operate it at.
The pololu link above shows a good number of stepper controllers that can handle this current - most will need a heatsink. You can of course also run your stepper at lower than rated current, but you will be losing torque.
I suggest you get a driver that can handle at least 3 amps to give yourself some headroom. It is not a good idea to run electronic equipment at its limit.
