Most tutorials or documentation about Stepper Motors do not use the ENA pin, to me if I would like to use it and I can not think of a way to do it, some help?
The code that I have only uses DIR and PUL, and the documentation of the library does not say anything about ENA.
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// set the speed at 60 rpm:
myStepper.setSpeed(60);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
I want to use it to turn off the Stepper Motor when I are not using it. Because the one who uses will be portable (I will use a battery), so if it is always ignited, it will consume incessary energy.
As you know, a Stepper Motor on can not be moved by hand and is blocked, that is, it is maintained by consuming energy.
Sorry but I don’t get what you are not understanding.
Connect the ENA pin to an Arduino pin, and set it high or low depending on if you want the motor to be enabled or disabled.
Check the data sheet of your driver to see what logic level activates the motor.
