Hello Arduino fans,
31 year old female, first time programming, first time poster.
One month ago I ordered an Arduino Mega kit for an exploration into creating a product. I need a stepper motor to turn 4 times during a 20 minute interval, and an LCD to display a few different words along with a countdown timer for the entire 20 minutes.
Getting the motor to turn, the words to display, and the timer to run have been a challenging success. My problem is when I ask the stepper motor to turn again, at a 5 minute interval. It seems I am unable to get out of the loop to have it turn, then return to the loop, while the countdown timer continues to run.
I have spliced code from all corners of the internet to get as far as I have and a few suggestions would be appreciated.
// int minutes says 20 though I test with lower numbers.
// Thank you in advance.
Chelsea
#include <CountUpDownTimer.h>
#include <LiquidCrystal.h>
#include <Stepper.h>
int hours = 0; // start hours
int minutes = 20; //start min
int seconds = 0; //start seconds
#define STEPS_PER_MOTOR_REVOLUTION 32
#define STEPS_PER_OUTPUT_REVOLUTION 32 * 64 //2048
Stepper myStepper(STEPS_PER_MOTOR_REVOLUTION, 8, 10, 9, 11);
// Numbers of the interface pins
LiquidCrystal lcd(0, 1, 2, 3, 4, 5);
const int stepsPerRevolution = 32; // number of steps per revolution
// for my motor
int step();
lcd.begin(16,2);
lcd.setCursor(0, 0);
lcd.print("");
lcd.setCursor(0,1);
lcd.print("_");
delay(4000);
lcd.clear();
// for now I am programming it to run the tendon program
lcd.print("Increasing");
lcd.setCursor(0,1);
lcd.print("to Level 40");
myStepper.setSpeed(100); // = 1667 milliseconds
myStepper.step(200);
lcd.clear();
lcd.print("Lvl. 40 - 5 MIN");
lcd.setCursor(0,1);
lcd.print("Remaining");
while (minutes > 0 || seconds >= 0) {
lcd.setCursor(11, 1);
(minutes < 10) ? lcd.print("0") : NULL;
lcd.print(minutes);
lcd.print(":");
(seconds < 10) ? lcd.print("0") : NULL;
lcd.print(seconds);
lcd.display();
stepDown();
/* This is where I encounter the problem. After 5 out of 20 minutes has passed,
- I need the stepper motor to take another 350 steps and wait for 6 minutes.
- After 6 minutes I need it to take another 350 steps and wait for 6 minutes.
- then I need it to take 850 reverse steps and wait until the 20 minute timer runs out.
- It seems no matter how I attempt to break the loop my lcd gets screwed up or my
- stepper motor does not pause for the amount of time it needs to, but rather, just continues to rotate
- and then pause.
- OR NOTHING happens and the stepper does not turn again and the timer just runs out.
void stepDown() {
if (seconds > 0) {
seconds -= 1;
if (minutes > 0) {
seconds = 59;
minutes -= 1;
if (hours > 0) {
seconds = 59;
minutes = 59;
hours -= 1;
trigger();
void trigger() {
lcd.clear(); // clears the screen and buffer
lcd.setCursor(5, 1); // set timer position on lcd for end.
lcd.println("END");
lcd.display();
