My project light-sensitive automatic opening and closing curtains…stepper motor does not stop after 90 degrees
// This Arduino example demonstrates bidirectional operation of a
// 28BYJ-48, using a ULN2003 interface board to drive the stepper.
// The 28BYJ-48 motor is a 4-phase, 8-beat motor, geared down by
// a factor of 68. One bipolar winding is on motor pins 1 & 3 and
// the other on motor pins 2 & 4. The step angle is 5.625/64 and the
// operating Frequency is 100pps. Current draw is 92mA.
//declare variables for the motor pins
int motorPin1 = 2; // Blue - 28BYJ48 pin 1
int motorPin2 = 4; // Pink - 28BYJ48 pin 2
int motorPin3 = 3; // Yellow - 28BYJ48 pin 3
int motorPin4 = 5; // Orange - 28BYJ48 pin 4
int sayi;
int sayii; // Red - 28BYJ48 pin 5 (VCC)
int ldr = 0;
int ldr_value = 10;
int motorSpeed = 1200; //variable to set stepper speed
int count = 0; // count of steps made
int countsperrev = 256; // number of steps per full revolution
int lookup[8] = {B01000, B01100, B00100, B00110, B00010, B00011, B00001, B01001};
//declare the motor pins as outputs
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
void loop(){
if(ldr_value = analogRead(ldr))
Serial.println(ldr_value); //prints the LDR values to serial monitor
delay(10);
clockwise();
else if (count == countsperrev * 2)
count = 0;}
else{
anticlockwise();
count++;
//set pins to ULN2003 high in sequence from 1 to 4
//delay "motorSpeed" between each pin setting (to determine speed)
void anticlockwise()
for(int i = 0; i < 8; i++)
setOutput(i);
delayMicroseconds(motorSpeed);
void clockwise()
for(int i = 7; i >= 0; i--)
setOutput(i);
void setOutput(int out)
digitalWrite(motorPin1, bitRead(lookup[out], 0));
digitalWrite(motorPin2, bitRead(lookup[out], 1));
digitalWrite(motorPin3, bitRead(lookup[out], 2));
digitalWrite(motorPin4, bitRead(lookup[out], 3));
