stepper motor help!
so I purchased a stepper motor from ebay: 5V 28BYJ-48 4-Phase Stepper Motor with ULN2003 Driver Board Arduino and hooked it up to my arduino board....at the moment i'm using the standard MotorKnob code i found on the Arduino website: http://arduino.cc/en/Tutorial/MotorKnob and its working fine.
However, I want to add a delay time between each step.....where my total steps per revolution will be 24....but full steps to be 8760....Does anyone know how i can add this info into the software....ALSO, is it possible to add another 5V stepper motor to the arduino and how would i program it so both stepper motors move at the same rate in the same direction.
I'm not very experienced with using Arduino...so any help will be great!
http://embeddedsystem1.blogspot.in/search/label/stepper%20motor
For more steppers you just define more Stepper objects with the appropriate pin numbers - however then you have to control both simultaneously which suggests you could study the BlinkWithoutDelay example.
