stepper motor how to control 2 stepper motor with different angle position
Hi everyone, i need your help for a project.
My actual part list:
-2 x Nema 17 stepper motor
-2 x drv8825 stepper driver
-arduino uno
-12v DC power supply 10A
-2 push button switch
-2 resistors 10k ohm
I have to program 2 stepper motors so that when a push button is pressed, stepper motor 1 rotates 30degrees (16.66 steps) and then after 1000microseconds stepper motor 2 rotates 90 degree (50).
Then stepper motor 1 rotates 60 degrees (33.33 steps) and after 1000 microseconds stepper motor rotates 90 degrees (50steps).
When push button 2 is pressed, different sequence is done with the motors.
If you can help me on the first sequence, the second will be straight forward.
Anything is additional is required for the project, please let me know.
Thank you so much
BOOM90:
If you just want someone to write a program for you please ask in the Gigs and Collaborations section of the Forum and be prepared to pay.
If you want to learn to program yourself then these links may help get you started.
Stepper Motor Basics
Simple Stepper Code
...R
I’d consider learning how to use the AccelStepper - you can create multiple instances of a motor and drive them however you like. It has examples, but basically so long as every instance gets its run() method called frequently it will just do the right thing for you.
