hello, i have problem with combine 1 sample program with a i2c display. whem i try to combine it, something is no working... i am now combined all togeder, but motor have delay every one step. van somebody help???
i am using this code
http://www.schmalzhaus.com/EasyDriver/Examples/EasyDriverExamples.html
// Example5 code for Brian Schmalz's Easy Driver Example page
// http://www.schmalzhaus.com/EasyDriver/EasyDriverExamples.html
#include <AccelStepper.h>
// Define the stepper and the pins it will use
AccelStepper stepper1(AccelStepper::DRIVER, 9, 8);
// Define our three input button pins
#define LEFT_PIN 4
#define STOP_PIN 3
#define RIGHT_PIN 2
// Define our analog pot input pin
#define SPEED_PIN 0
// Define our maximum and minimum speed in steps per second (scale pot to these)
#define MAX_SPEED 500
#define MIN_SPEED 0.1
// The only AccelStepper value we have to set here is the max speeed, which is higher than we'll ever go
stepper1.setMaxSpeed(10000.0);
// Set up the three button inputs, with pullups
pinMode(LEFT_PIN, INPUT_PULLUP);
pinMode(STOP_PIN, INPUT_PULLUP);
pinMode(RIGHT_PIN, INPUT_PULLUP);
static float current_speed = 0.0; // Holds current motor speed in steps/second
static int analog_read_counter = 1000; // Counts down to 0 to fire analog read
static char sign = 0; // Holds -1, 1 or 0 to turn the motor on/off and control direction
static int analog_value = 0; // Holds raw analog value.
// If a switch is pushed down (low), set the sign value appropriately
if (digitalRead(LEFT_PIN) == 0) {
sign = 1;
else if (digitalRead(RIGHT_PIN) == 0) {
sign = -1;
else if (digitalRead(STOP_PIN) == 0) {
sign = 0;
// We only want to read the pot every so often (because it takes a long time we don't
// want to do it every time through the main loop).
if (analog_read_counter > 0) {
analog_read_counter--;
else {
analog_read_counter = 3000;
// Now read the pot (from 0 to 1023)
analog_value = analogRead(SPEED_PIN);
// Give the stepper a chance to step if it needs to
stepper1.runSpeed();
// And scale the pot's value from min to max speeds
current_speed = sign * (((analog_value/1023.0) * (MAX_SPEED - MIN_SPEED)) + MIN_SPEED);
// Update the stepper to run at this new speed
stepper1.setSpeed(current_speed);
// This will run the stepper at a constant speed
i am trying to show % of SPEED_PIN 0
this is now working code, but with delay on motor steps...
//LCD config
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); //sometimes the LCD adress is not 0x3f. Change to 0x27 if it dosn't work.
#define LEFT_PIN 4
#define STOP_PIN 3
#define RIGHT_PIN 2
#define SPEED_PIN 0
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("Joker 3D");
lcd.setCursor(1,1);
lcd.print("Camera slider v4.4");
static float percent = 0.0;
sign = 1;
sign = -1;
sign = 0;
else {
lcd.clear();
lcd.setCursor(1,0);
lcd.print("speed");
lcd.setCursor(3,1);
lcd.print(percent);
lcd.setCursor(9,1);
lcd.print("%");
percent = sign * (analog_value * 0.0977517107);
thanks for helping
