Stepper motor in only one way
Hi, I've a problem with my stepper motor, or with my driver or with IDE, I don't know. I've tried A4988 and tmc2208, with my arduino mega and with my cnc shield, the stepper motor only goes forward, I aso tried with 2 other stepper and they work in the same way. I don't know, I've aredy written a code with stepper motor that works with mobatools and with accelstepper and they work but now a simple code doesn't works at all and I don't know why.
I left my code below:
```cpp
// Includo le librerie necessarie
#include <MobaTools.h>
long step = 500;
// Definizione dei pin dell'Arduino
// Pin dello stepper motor
const byte enablePin = 8;
// Definizione del driver dello stepper motor
MoToStepper stepper(200, STEPDIR);
// Setup
  pinMode(enablePin, OUTPUT);
  stepper.attach(3, 6);
  stepper.attachEnable(enablePin, 1, LOW);
  stepper.setSpeed(100);
// Loop
  stepper.doSteps(-step);
  stepper.doSteps(step);
thanks to everyone that helps me, and sorry for my english
The MobaTools methods ore not blocking. So immediately after commanding the stepper to go ccw, you command it to go cw. Then it turns while the delay.
You must give the stepper time to go backwards - either by a delay, or by checking if it's still moving.
I added a deay but it still not working, can I have a problem with arduino and computer?
```cpp
#include <AccelStepper.h>
// Definisci il numero di passi per giro completo del motore
const int stepsPerRevolution = 2000;
// Collega i pin del driver del motore stepper
const int stepPin = 3;
const int dirPin = 6;
// Crea un oggetto AccelStepper
AccelStepper stepper(1, stepPin, dirPin);  // ModalitĂ  driver: 1
  // Imposta la velocitĂ  massima (in steps per secondo)
  stepper.setMaxSpeed(1000);
  // Imposta l'accelerazione (in steps per secondo al secondo)
  stepper.setAcceleration(200);
  stepper.setPinsInverted(true, false, true);
  // Inizializza la posizione del motore
  stepper.setCurrentPosition(0);
  // Fai girare il motore in avanti
  stepper.move(stepsPerRevolution);
  // Attendi che il motore raggiunga la posizione desiderata
  while (stepper.distanceToGo() != 0) {
    stepper.run();
  // Pausa per un secondo
  stepper.move(0);
    stepper.run();
With this code it goes only forward and not backward, why?
My advice was related to your original Sketch. Where did you insert the delay?
Now you show something completely different. This sketch never changes the direction of the motor.
And please post a schematic of your wiring.
because you changed from the MobaTools-library
to the AccelStepper-library.
change it back and stay with the MobaTools-library
For making visible what your code is doing load this sketch
open the serial monitor and watch what gets printed
Then you will understand what the code really does.
long step = 500;
// Setup
  Serial.println("Setup-Start");
  Serial.println("exiting Setup");
// Loop
  Serial.println("Top of loop");
  Serial.println("MINUS steps stepper.doSteps(-step) executed");
  Serial.println("PLUS steps stepper.doSteps(step) executed");
  Serial.println("delay(1000); finished");
best regards Stefan
YMMD :slight_smile:
Autocorrection and wrong language :flushed::joy:
