Stepper motor issue
I have placed some sensors on my stepper motor with an arduino which is transmitting the data to my laptop python program, however when I run this code the motor blocks for a fraction of milliseconds due to the calculation of the sensor values. Is there a way to incorporate a multithread in this code so as the motor run smoothly?
Here is the code:#include <AccelStepper.h>
#include <Adafruit_MLX90614.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <SPI.h>
#include <RF24.h>
#define dirPin 2
#define stepPin 3
#define motorInterfaceType 1
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified();
unsigned long previousMillis = 0; // Stores the last time temperature and current were read
const long interval = 1000; // Interval at which to read temperature and current (milliseconds)
const int analogInPin = A0; // Analog input pin that the current sensor is attached to
int sensorValue = 0; // Value read from the sensor
float voltage = 0; // Variable to store the voltage
float current = 0; // Variable to store the current
enum TaskState {
READ_TEMP,
READ_CURRENT,
READ_ACCEL,
PRINT_ALL,
TRANSMIT_ACCEL,
IDLE
TaskState taskState = IDLE;
float ambientTemp = 0.0;
float objectTemp = 0.0;
float acceleration_magnitude = 0.0;
while (!Serial);
// Attempt to initialize MLX90614
if (!mlx.begin()) {
    //Serial.println("Error connecting to MLX sensor. Check wiring.");
// Attempt to initialize ADXL345
if (!accel.begin()) {
   // Serial.println("No valid ADXL345 sensor found");
stepper.setMaxSpeed(20000); // Maximum speed in steps per second
stepper.setSpeed(10000);    // Initial speed in steps per second
// Non-blocking state machine for reading and transmitting data
switch (taskState) {
    case READ_TEMP:
        if (mlx.begin()) {
            ambientTemp = mlx.readAmbientTempC();
            if (isnan(ambientTemp)) {
                ambientTemp = 0;
            objectTemp = mlx.readObjectTempC();
            if (isnan(objectTemp)) {
                objectTemp = 0;
        taskState = READ_CURRENT;
    case READ_CURRENT:
        sensorValue = analogRead(analogInPin);
        voltage = sensorValue * 5.0 / 1023.0;
        current = (voltage - 2.5) / 0.185;
        taskState = READ_ACCEL;
    case READ_ACCEL:
        if (accel.begin()) {
            sensors_event_t event;
            accel.getEvent(&event);
            acceleration_magnitude = sqrt(event.acceleration.x * event.acceleration.x +
                                          event.acceleration.y * event.acceleration.y +
                                          event.acceleration.z * event.acceleration.z);
            if (isnan(acceleration_magnitude)) {
                acceleration_magnitude = 0;
        taskState = PRINT_ALL;
    case PRINT_ALL:
        // Print all sensor values on a single line
        Serial.print(ambientTemp);
        Serial.print(",");
        Serial.print(objectTemp);
        Serial.print(",");
        Serial.print(current);
        Serial.print(",");
        Serial.print(acceleration_magnitude);
        taskState = TRANSMIT_ACCEL;
    case TRANSMIT_ACCEL:
        // Placeholder for transmitting acceleration data
        // Add your transmission code here
        taskState = IDLE;  // Go back to IDLE after transmission
    case IDLE:
        // Do nothing, wait for the next interval
// Check if it's time to read and print temperature and current
if (taskState == IDLE && (currentMillis - previousMillis >= interval)) {
    taskState = READ_TEMP;
// Check for serial input to adjust the motor speed
if (Serial.available() > 0) {
    String input = Serial.readStringUntil('\n');
    float newSpeed = input.toFloat();
    stepper.setSpeed(newSpeed);
   // Serial.print("Motor speed set to: ");
   // Serial.println(newSpeed);
// Continuous motor run
stepper.runSpeed();
Even though i remove this line, it continues to block. Is there a multithreading option?
Use a much higher Baud rate for serial.Print(). Only print if something changes from the previous value.
Be sure to format and post your code using the < CODE > button... your posted code should look like this:
#include <Wire.h>
#include <SPI.h>
#include <RF24.h>
#define dirPin 2
#define stepPin 3
enum TaskState {
  READ_TEMP,
  READ_CURRENT,
  READ_ACCEL,
  PRINT_ALL,
  TRANSMIT_ACCEL,
  IDLE
  while (!Serial);
  if (!mlx.begin()) {
    case READ_TEMP:
      if (mlx.begin()) {
          ambientTemp = 0;
          objectTemp = 0;
    case READ_CURRENT:
    case READ_ACCEL:
    case PRINT_ALL:
      Serial.print(",");
      Serial.print(",");
      Serial.print(",");
    case IDLE:
  stepper.runSpeed();
