When reviewing the spec sheet for the subject Mitsumi motor, there are specs for both 12V and 24V. My questions are:
(1) Where two different motors sold or does this suggest a range for the M42SP-6NK6NK, and
(2) The spec sheet for this motor indicates each phase rated at 2.0 Amp, 1.1 Ohm resistance, and a Rated Voltage per Phase to be 2.2. How does either 12 or 24 voltages correspond to the latter specifications? It seems to me the spec sheet implies I need a 2.2 voltage source that capable capable of delivering not more than a total of 4.0 amps (2 amps per phase).
This may have been answered by Robin2's post in December of 2014 which stated "the rated voltage was irrelevant, it was maintaining the current below the maximum rated value" was the parameter of concern. I've thought about this last question considerably and can't make logical sense of the numbers, so I would greatly appreciate someone confirming my understanding of the Robin2 post or explaining the conflict between voltage source range and maximum phase voltage.
