stepper motor - make it quieter
Greetings.
Not sure if this question qualifies as a proper question for this forum, but here it is:
I have a stepper that you can't hear it running if you keep it in your hand, but as soon as it place it in it's mounting place (a wooden plank), you can hear it vibrating / resonating.
Do you guys have any tips or tricks on how to mount a stepper motor so it makes as little sond as possible?
Because they move in steps stepper motors are going to cause resonance. Can you mount it in rubber grommets without affecting its relationship with whatever it is driving?
A more dense board may also help to reduce the noise.
...R
You might also play around with different microstepping modes - if applicable by your driver.
That modifies the "sound" a bit and if you get further away from the self resonance of the wooden piece it might help in addition to @Robin2's advice.
Use microstepping, mount on visco-elastic mountings, or just live with the noise - steppers are noisy.
