Hey all,
I'm making a school project where i wanna use a stepper motor to move a carriage. I'm using a keypad to provide input and an lcd board to show the ouput. I'm using an Accelstepper library and a microstepper controller.
the problem is, its very inaccurate when it comes to steps, i.e. i need it to be very accurate , to .mm to be precise, and its missing steps. I know the code is very wonky, but is there a way to solve this?
Below is the code:
#include <AccelStepperWithDistance.h>
#include <Keypad.h>
//#include <AccelStepper.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
AccelStepper stepperX(1, 12, 11); // 1 = Easy Driver interface
//const uint8_t KEYPAD_ADDRESS = 0x27;
//I2CKeyPad Keypad(KEYPAD_ADDRESS);
const byte home_switch = 13;
// Stepper Travel Variables
long TravelX; // Used to store the X value preovided by the user
bool moveComplete = true;
bool halt=false;
//keypad setup
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 4; //four columns
char keys[ROW_NUM][COLUMN_NUM] = {
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
//byte pin_rows[ROW_NUM] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
//byte pin_column[COLUMN_NUM] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
//alternate
byte pin_rows[ROW_NUM] = {6,7,8,9}; //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {3,2,4,5}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
String keypadInput;
void lcdEnterValue() {
lcd.clear();
lcd.print(F("set value:"));
lcd.setCursor(0, 1);
lcd.print("now at ");
lcd.print(stepperX.currentPosition());
lcd.setCursor(10, 0);
Serial.println(F("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): "));
bool readKeypad(long& newDestination) {
long userInput = 0;
char key = keypad.getKey();
if (key) {
if (key >= '0' && key <= '9') { // only act on numeric keys ==> HOW DO YOU ENTER NEGATIVE VALUES?
keypadInput += key; // append new character to input string
lcd.print(key);
} else if (key == '#') {
if (keypadInput.length() > 0) {
stepperX.enableOutputs();
userInput = keypadInput.toInt();
keypadInput = ""; // clear input
halt=false;
if (userInput < 0 || userInput > 69500) { // Make sure the position entered is not beyond the HOME or MAX position
Serial.println(F("\nPlease enter a value greater than zero and smaller or equal to 69500.....\n"));
lcd.clear();
lcd.print(F("invalid value."));
delay(2000);
lcdEnterValue();
return false;
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(F("Moving to:"));
lcd.print(userInput);
Serial.print(F("Moving stepper into position: "));
Serial.println(userInput);
delay(1000); // Wait 1 seconds before moving the Stepper
newDestination = userInput;
return true;
else if (key == '*') {
lcdEnterValue();
else if (key == 'A'){
stepperX.disableOutputs();
lcd.print("Halted");
halt=true;
return false;
void homing() {
// Set Max Speed and Acceleration of each Steppers at startup for homing
stepperX.setMaxSpeed(800.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(800.0); // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
lcd.print(F("HOMING"));
Serial.print("Stepper is Homing");
long initial_homing = -1; // Used to Home Stepper at startup
while (digitalRead(home_switch) == HIGH) {
stepperX.moveTo(initial_homing); // Set the position to move to
initial_homing--; // Decrease by 1 for next move if needed
stepperX.run(); // Start moving the stepper
delay(1);
stepperX.setCurrentPosition(0); // Set the current position as zero for now
stepperX.setMaxSpeed(100.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(100.0); // Set Acceleration of Stepper
initial_homing = 1;
delay(15); // anti-bounce
while (digitalRead(home_switch) == LOW) {
initial_homing++;
stepperX.run();
delay(1);
lcd.clear();
lcd.print(F("HOMING DONE!"));
delay(2500);
Serial.println(F("Homing OK\n"));
pinMode(home_switch, INPUT_PULLUP);
Serial.begin(115200); // don't go slow.
keypadInput.reserve(10); // avoid dynamic allocation
keypadInput == ""; // empty the String
lcd.init(); // initialize the lcd
lcd.clear();
lcd.backlight();
homing();
stepperX.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Faster for regular movements)
stepperX.setAcceleration(500.0); // Set Acceleration of Stepper
// Print out Instructions on the Serial Monitor at Start
lcdEnterValue();
if (readKeypad(TravelX)) {
stepperX.moveTo(TravelX); // Set new moveto position of Stepper
moveComplete = false;
// Check if the Stepper has reached desired position
if ((stepperX.distanceToGo() != 0) && halt== false) {
stepperX.run(); //stepperX.runSpeed() DID NOT WORK
if (!moveComplete) {
lcd.clear();
lcd.print("COMPLETED!");
delay(2500);
Serial.println("COMPLETED!");
lcdEnterValue();
