Stepper motor MOVES_STOP_MOVES
Hi!
I am currently working on a bit of code involving 2 temp gauges, lcd, relay, 1 stepper motor but it seems like the code around my for for statement pulsing the stepper drive causes som kind of delay making the stepper motor too move for 1 sec and then stop 1 sec and so on. I think I should need to run 2 loops simultaneously. Is there a way of doing this?
Best regards
Victor
you have a small bug at line 9 of your for loop... (at least as far as I can see :o )
:sweat_smile:
or isit at line 10...
demkat1:
it depends if you start counting at line 0 or line 1.... :slight_smile:
timesincestarts = millis(); //Counting millis to minutes
timesincestart= timesincestarts/ minute;
Serial.println(timesincestart);
//Button
reading = digitalRead(inPin); //Reading the value of the button and setting reading
// if the input just went from LOW and HIGH and we've waited long enough
// to ignore any noise on the circuit, toggle the output pin and remember
// the time
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH)
state = LOW;
state = HIGH;
time = millis();
if(state == HIGH)
//Tempmätare Serial
uint16_t rtd = max.readRTD();
float ratio = rtd;
ratio /= 32768;
Serial.print("Temperature = "); Serial.println(max.temperature(RNOMINAL, RREF)); //Writing Temperatur c value on second line of serial monitor
TempC = max.temperature(RNOMINAL, RREF);
//Tempgauge 2
sensors.requestTemperatures(); //Get temp
TempC2 = sensors.getTempCByIndex(0); //Turning it to degres
//The different sequences
if(0 <= timesincestart && timesincestart < sequence1 )
Settemp = temp1;
Setspeed = speed1;
currentsequence = 1;
if(sequence1 < timesincestart && timesincestart < (sequence2 + sequence1))
Settemp = temp2;
Setspeed = speed2;
currentsequence = 2;
if((sequence2 + sequence1) < timesincestart && timesincestart < (sequence3 + sequence2 + sequence1))
Settemp = temp3;
Setspeed = speed3;
currentsequence = 3;
if((sequence3 + sequence2 + sequence1) < timesincestart && timesincestart < (sequence4 + sequence3 + sequence2 + sequence1))
Settemp = temp4;
Setspeed = speed4;
currentsequence = 4;
if((sequence4 + sequence3 + sequence2 + sequence1) < timesincestart && timesincestart < (sequence5 + sequence4 + sequence3 + sequence2 + sequence1))
Settemp = temp5;
Setspeed = speed5;
currentsequence = 5;
if((sequence5 + sequence4 + sequence3 + sequence2 + sequence1) < timesincestart && timesincestart < (sequence6 + sequence5 + sequence4 + sequence3 + sequence2 + sequence1))
Settemp = temp6;
Setspeed = speed6;
currentsequence = 6;
if((sequence6 + sequence5 + sequence4 + sequence3 + sequence2 + sequence1) < timesincestart && timesincestart > (sequence7 + sequence6 + sequence5 + sequence4 + sequence3 + sequence2 + sequence1))
Settemp = speed7;
Setspeed = speed7;
currentsequence = 7;
if((sequence7 + sequence6 + sequence5 + sequence4 + sequence3 + sequence2 + sequence1) < timesincestart && timesincestart < (sequence8 + sequence7 + sequence6 + sequence5 + sequence4 + sequence3 + sequence2 + sequence1))
Settemp = temp8;
Setspeed = speed8;
currentsequence = 8;
if(sequence8 < timesincestart) //Timear den ut så når den inte setcurrent
previous = HIGH;
state = LOW;
currentsequence = 9;
//Count
Setspeedcalc = 3/(10*Setspeed+1);
//Seriall Monitor
lcd.clear();
lcd.setCursor (0,0);
lcd.print("Sequence");
lcd.setCursor(9,0);
lcd.print(currentsequence);
lcd.setCursor(0,1);
lcd.print("Temp:");
lcd.print(TempC);
lcd.setCursor(8,1);
lcd.print("RPM:");
lcd.print(Setspeed);
//Motor kontroll
digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
// Makes 200 pulses for making one full cycle rotation
for(int x = 0; x < stepsPerRevolution; x++) {
digitalWrite(stepPin,HIGH);
digitalWrite(stepPin,LOW);
delay(Setspeedcalc);
//if sats
if (TempC < Settemp && TempC != -247) { //Relay control with failsafe
analogWrite(relaych1, 1);
Serial.println("YES"); //diagnotsik
if (TempC > Settemp) {
analogWrite(relaych1, 0);
Serial.println("NO"); //diagnostik
//Nollställa värden
sensorValue = 0; // återställer värdet innan nästa loop
else if(currentsequence == 9)
digitalWrite(relaych1, 0);
lcd.clear();
lcd.print("Finish!");
previous = reading;
To make it easy for people to help you please modify your post and use the code button </>
so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor. The text editor shows line numbers, identifies matching brackets and allows me to search for things like all instances of a particular variable or function.
Also please use the AutoFormat tool to indent your code for easier reading.
A FOR loop may indeed interfere with the progress of the program. Use IF and allow loop() to do the iteration.
...R
Several Things at a Time
Stepper Motor Basics
Simple Stepper Code
