I've been trying o achieve the goal of turning the stepper acc. to Gcodes i enter. But, my stepper motor shows no response to any of the Gcodes i enter in serial monitor.
I'm using GRBL1.1 and latest arduino.
I think the bit you are missing is the Arduino UNO sketch that accepts the Gcodes, parses them and drives the stepper.
Warning none of the links below parse Gcode but should give you some ideas
I am not aware of any version of grbl that supports L298 drivers. Grbl uses step/dir drivers like A4988 or DRV8825. What version of grbl do you have that is modified to use the L298?
What exact stepper motors do you have? Post a data sheet.
If the steppers are bipolar and the coil current is less than 1A, the A4988 is good. Up to 1.5A the DRV8825, 0.5A to 4A the TB6600 drivers are popular. Those are all step/dir type drivers.
All of those driver will need the coil current to be set before they are used. See instructions on the linked pages.
Unipolar steppers usually do not take an H-bridge to run. Can you post a schematic of your wiring?
I found this. It is supposed to work with 4 wire H-bridge drivers. I have no idea if it will work for you.
My thought is that if you want to work with grbl, use steppers and drivers that grbl was written for. And, with an Uno, the CNC shield makes a lot of sense. It is set up to use grbl with very little work. The CNC shield has accommodations for limit switches and other control signals as well as stepper drivers.
No dice I'm afraid, you'd need 4 pins per stepper for unipolar use and there aren't enough pins!
Bipolar motors driven by a step+direction stepper driver are required for GRBL.
Also you don't get microstepping drivers for unipolars which is probably a show-stopper anyway, microstepping is vital for vibration and resonance control.
How many wires is the motor? 6 and 8-wire motors can be used both unipolar and bipolar, 5-wire can't.
