#include <Wire.h>
#include <AccelStepper.h>
int motorDirPin = 9;
int motorStepPin = 10;
AccelStepper stepper(1, motorStepPin, motorDirPin);
int pos=0;
int LUXAddress = 0x4A; // Device address in which is also included the 8th bit for selecting the mode, read in this case.
#define LUX_High_Byte 0x03 //data register
#define LUX_Lower_Byte 0x04
Wire.begin(); // Initiate the Wire library
delay(100);
stepper.setMaxSpeed(3000);
stepper.setAcceleration(1000);
int X0 = registerVal(LUX_High_Byte);
int X1 = registerVal(LUX_Lower_Byte);
int exponent=(X0&0xf0)>>4;
int mant=(X0&0x0f)<<4|X1;
float val = (float)(pow(2,exponent)*mant)*0.045;
Serial.print(" LUX: ");
Serial.println(val);
if(val>100){
pos-=3600;
stepper.moveTo(pos);
pos+=3600;
stepper.run();
delay(4000);
int registerVal(int address)
Wire.beginTransmission(LUXAddress); // Begin transmission to the Sensor
//Ask the particular registers for data
Wire.write(address);
Wire.endTransmission();
Wire.requestFrom(LUXAddress,1);
return Wire.read();
I wrote two different codes for stepper motor and LUX. When I combined them both, the motor isn’t rotating. Why isn’t the motor rotating for this code?
For stepper.run() to work properly there should be no delay() and loop() should be able to repeat hundreds or thousands of times per second.
If some other part of the code needs to happen only once every 4 seconds then use millis() to manage timing without blocking as illustrated in Several things at a time
I am assuming you have had no problem getting your motor to run with a simple program?
#include <Wire.h>
const int dir=9;
const int pul=10;
int i,input;
pinMode(dir, OUTPUT); //direction pin
pinMode(pul, OUTPUT); //step pin
digitalWrite(pul, LOW);
Wire.begin();
Serial.println("Starting");
input=Serial.read();
if(val>150)
digitalWrite(dir, HIGH);
Serial.write(input);
Serial.write(" Anti Clockwise\n");
for(i=0;i<800;i++){
digitalWrite(pul, HIGH);
delayMicroseconds(1000);
digitalWrite(pul,LOW);
else if(input<150)
digitalWrite(dir, LOW);
Serial.write(" Clockwise\n");
for(i=0;i<800;i++){
return Wire.read();
