Stepper motor only rotates 1 step, or keeps rotating.
So I'm trying to write a program that allows me to turn a stepper motor on and off wirelessly through an app.
For the wireless connection, I use a NodeMcu ESP8266 and for the motor driver, I use an EasyDriver v4.5.
I programmed the app with MIT App Inventor and the app works well.
The problem is that either my motor turns 1 step (after I turn it on through the app) (first program), or it keeps rotating when I turn the motor on through the app but I can't turn it off (second program). I've tried so many things for days but none of them seem to work.
So what I want is that when I press the "LedAan" button in the app, the motor keeps rotating until I press the "LedUit" button in the app.
I think the problem in the first program is that the wifi client request is "blocking" the other code unless it receives an input (through my app).
I'm sure the driver and motor are working correctly since those work flawlessly in a standalone program I wrote.
I've only been programming for a year so I'm not that good and my way of working / programming might be inefficient.
First program:
#include <ESP8266WiFi.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
const char WiFiPassword[] = "StarTracker";
const char AP_NameChar[] = "StarTracker" ;
#define SCREEN_WIDTH 128 //breedte OLED scherm (in pixels)
#define SCREEN_HEIGHT 64 //hoogte OLED scherm (in pixels)
#define OLED_RESET     LED_BUILTIN
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //configureert het display met de juiste settings
WiFiServer server(80);
String header = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
String html_1 = "<!DOCTYPE html><html><head><title>LED Control</title></head><body><div id='main'><h2>LED Control</h2>";
String html_2 = "<form id='F1' action='LEDON'><input class='button' type='submit' value='LED ON' ></form>
String html_3 = "<form id='F2' action='LEDOFF'><input class='button' type='submit' value='LED OFF' ></form>
String html_4 = "</div></body></html>";
String request = "";
static const uint8_t LED = 16;
int BuiltinLedHIGH = 0;
int BuiltinLedLOW = 1;
int StarTrackerMain = 0;
int MotorStep = 12;
int MotorDir = 14;
int OLEDPRINTED = 0;
  pinMode(LED, OUTPUT);
  digitalWrite(LED, BuiltinLedLOW);
  pinMode (14, OUTPUT);  //MotorDir output
  digitalWrite (14, LOW);  //MotorDir LOW
  pinMode (12, OUTPUT);  //MotorStep output
  digitalWrite (12, LOW);  //MotorStep LOW
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0, 0);
  display.println("LED = Uit");
  display.display();
  boolean conn = WiFi.softAP(AP_NameChar, WiFiPassword);
  server.begin();
} // void setup()
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client)  {
    return;
  // Read the first line of the request
  request = client.readStringUntil('\r');
  if       ( request.indexOf("LedAan") > 0 )  {
    StarTrackerMain = 1;
    OLEDPRINTED = 0;
  else if  ( request.indexOf("LedUit") > 0 ) {
    OLEDPRINTED = 0;
  if (StarTrackerMain == 1 & OLEDPRINTED == 0) {
    digitalWrite(LED, BuiltinLedHIGH);
    display.display();
    display.println("LED = Aan");
    display.display();
    OLEDPRINTED = 1;
  if (StarTrackerMain == 1) {
    digitalWrite (12, HIGH);
    delay(1);
    delay(1);
  if (OLEDPRINTED == 0) {
    display.display();
    display.display();
    OLEDPRINTED = 1;
  client.flush();
  client.print( header );
  client.print( html_1 );
  client.print( html_2 );
  client.print( html_3 );
  client.print( html_4);
  delay(5);
  // The client will actually be disconnected when the function returns and 'client' object is detroyed
Second program:
int MotorStep = 12;
int MotorDir = 14;
char user_input;
int OLED = 0;
  display.display();
  server.begin();
  WiFiclient();
  MotorOn();
  MotorOff();
void WiFiclient() {
  if (!client)  {
    return;
    OLED = 1;
    OLED = 1;
  client.flush();
  delay(5);
void MotorOn() {
  if (StarTrackerMain == 1 & OLED == 1) {
    display.display();
    display.display();
    OLED = 0;
  while (StarTrackerMain == 1) {
    delay(1);
    delay(1);
void MotorOff() {
  if (StarTrackerMain == 0 & OLED == 1) {
    display.display();
    display.display();
    OLED = 0;
Referring to your second program and your motorOn() function ...
I don't understand why you have this
rather than the simpler
Likewise in the motorOff() function.
I think the major problem in your motorOn() function is this
because there is nothing inside that WHILE loop to change StarTrackerMain back to 0
I don't think you need the WHILE loop at all - try deleting it.
...R
Hi, you were completely right, that while loop caused my problems and that OLED variable wasn't needed. The OLED variable was used to make sure the for() loop would only run once but that's also the case without that variable.
I just found a way to control the motor without the while() function. I put the motor control code (which is the code below) in another "loop" and enabled / disabled the EasyDriver board through a digital signal from the NodeMcu. So instead of enabling / disabling the motor control loop, I just enabled / disabled the driver itself.
This is the motor control code that needs to be looped for the motor to rotate:
  delay(1);
  delay(1);
My new program now looks like this (the OLED variable is still there but it's already gone in my latest version):
int MotorStep = 12;
int MotorDir = 14;
int MotorEnablePin = 0;
  pinMode(MotorDir, OUTPUT);  //MotorDir output
  digitalWrite(MotorDir, LOW);  //MotorDir LOW
  pinMode(MotorStep, OUTPUT);  //MotorStep output
  digitalWrite(MotorStep, LOW);  //MotorStep LOW
  pinMode(MotorEnablePin, OUTPUT);
  digitalWrite(MotorEnablePin, HIGH);
  display.display();
  server.begin();
} // void setup()
  Motor();
  if (!client)  {
    return;
    OLEDPRINTED = 0;
    digitalWrite(MotorEnablePin, LOW);
    OLEDPRINTED = 0;
    display.display();
    display.display();
    OLEDPRINTED = 1;
  /*  if (StarTrackerMain == 1) {
      digitalWrite (MotorStep, HIGH);
      delay(1);
      digitalWrite (MotorStep, LOW);
      delay(1);
    display.display();
    display.display();
    OLEDPRINTED = 1;
  client.flush();
  delay(5);
void Motor() {
  delay(1);
  delay(1);
Also sorry for my bad English, I'm Dutch :wink:
Mr_BananaPants:
I had not noticed that there was anything wrong with it :slight_smile:
...R
Here's my final version (for now) which can also control the speed of the motor in case you wanted to know how I've fixed it. The code that controlled the OLED screen is also a lot more efficient. In case you have any suggestions or things that could've been done better, I'm happy to know!
/////LOCAL ACCESS POINT SETTINGS/////
/////OLED SETTINGS/////
/////HTML STRINGS/////
/////BUILTINLED PINS + VARIABLES/////
String MotorSnelheid = "traag";
String MotorStatus = "uit";
/////VARIABLES/////
int MotorSnel = 0;
/////VARIABLES/////
/////MOTOR CONNECTIONS/////
int MotorStep = 12;
int MotorDir = 14;
int MotorMS1 = 9;
int MotorMS2 = 10;
  /////BUILTINLED SETTINGS/////
  /////MOTOR SETTINGS/////
  pinMode(MotorEnablePin, OUTPUT);  //MotorEnablePin output
  pinMode(MotorMS1, OUTPUT);  //MotorMS1 output
  digitalWrite(MotorMS1, HIGH);  //MotorMS1 LOW
  pinMode(MotorMS2, OUTPUT);  //MotorMS2 output
  digitalWrite(MotorMS2, HIGH);  //MotorMS2 LOW
  display.display();
  /////START LOCAL ACCESS POINT + SERVER/////
  server.begin();
  /////START MOTOR + OLED VOID/////
  Motor();
  /////WIFI CLIENT/////
  if (!client)  {
    return;
  /////SERVER REQUESTS/////
  request = client.readStringUntil('\r');  //Leest de eerste regel van het request
  if       ( request.indexOf("StarTrackerMainAan") > 0 )  {
    MotorStatus = "aan";
  else if  ( request.indexOf("StarTrackerMainUit") > 0 ) {
  else if  ( request.indexOf("SpeedSnel") > 0 ) {
    digitalWrite(MotorMS2, LOW);
    digitalWrite(MotorMS1, LOW);
    MotorSnelheid = "snel";
  else if  ( request.indexOf("SpeedTraag") > 0 ) {
  /////OLED SCREEN STATUS + MOTOR SPEED/////
  display.setTextSize(1);
  display.print("Status: ");
  display.println(MotorStatus);
  display.print("Snelheid: ");
  display.println(MotorSnelheid);
  display.display();
  /////HTML RESPONSE/////
  client.flush();
  delay(5);
/////MOTOR DRIVER/////
void Motor() {
  delay(1);
  delay(1);
