Stepper motor problem
Hi
I am trying to use a stepper motor to actuate a blind with lightwaverf home automation protocol. It is a 4 wire 42BYGHW609 and is on an L293 based motor shield. It works with the AFmotor library example. However when I try to integrate that into the lightwaverf sketch it will only turn once. I suspect it could be something to do with interrupts but don’t know where to begin looking.
Here is the code:
#include <LwRx.h>
#include <EEPROM.h>
#include <string.h>
#define echo true
#include <AFMotor.h>
AF_Stepper motor(200, 1);
//lwrf code
static byte sideopen[10] = {1,15,0,1,3,2,10,14,9,7};
static byte sideclose[10] = {4,0,0,0,3,2,10,14,9,7};
int matchcounter = 0;
//Msg data
byte msg[10];
byte msglen = 10;
  lwrx_setup(2);
Serial.println(F("Set up ok"));
motor.setSpeed(100);  // in rpm
  if (lwrx_message()) {
    lwrx_getmessage(msg, msglen);
   if (comparemessage(msg, sideopen) == 10)
     blindup();
     if (comparemessage(msg, sideclose) == 10)
      blinddown();
//compare incoming messages to known codes
int comparemessage (byte * msg, byte * lwrfcommand)
  matchcounter = 0;
  for (int i = 0; i < 10; i++)
    if (msg[i] == lwrfcommand[i])
      matchcounter++;
  return matchcounter;
void blindup()
     motor.step(200, FORWARD, DOUBLE);
void blinddown()
  motor.step(200, BACKWARD, DOUBLE);
Any ideas?
