stepper motor problem
Hello , i need some help to add a feature in this sketch.
This sketch controls a stepper up and down by two buttons and counts the steps, another button reset the count.
I need to add another button to do, if the count is positive, brings the motor to 0 count ,one step at a time spaced by one minute.
Thanks.
const int dirPin  = 3;
const int stepPin = 4;
const int enPin   = 5;
const int LATCH = 2;   // pin 12 on 74hc595
const int CLK = 7;     // pin 11 on 74hc595
const int DATA = 6;    // pin 14 on 74hc595
const int switchUp     = 8;
const int switchDown   = 9;
const int switchReset  = 10;
byte displayDigit[11] = {
    0x3f, // 0
    0x06, // 1
    0x5b, // 2
    0x4f, // 3
    0x66, // 4
    0x6d, // 5
    0x7d, // 6
    0x07, // 7
    0x7f, // 8
    0x6f, // 9
    0x40  // -
int count = 0;
int UpbuttonState = 0;
int lastUpbuttonState = 0;
int DownbuttonState = 0;
int lastDownbuttonState = 0;
int ResetbuttonState = 0;
int lastResetbuttonState = 0;
bool bPress = false;
bool isUp = false;
bool isDown = false;
  pinMode( switchUp, INPUT_PULLUP);
  pinMode( switchDown, INPUT_PULLUP);
  pinMode( switchReset, INPUT_PULLUP);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  pinMode(enPin,OUTPUT);
  digitalWrite(enPin,LOW);
  pinMode(LATCH, OUTPUT);
  pinMode(CLK, OUTPUT);
  pinMode(DATA, OUTPUT);
  digitalWrite(LATCH, LOW);
  shiftOut(DATA, CLK, MSBFIRST, 113);
  shiftOut(DATA, CLK, MSBFIRST, 64);
  shiftOut(DATA, CLK, MSBFIRST, 109);
  digitalWrite(LATCH, HIGH);
   isUp = false;
   isDown = false;
   UpbuttonState = digitalRead(switchUp);
   DownbuttonState = digitalRead(switchDown);
   ResetbuttonState = digitalRead(switchReset);
    if (UpButtonPress()) {
    digitalWrite(dirPin,HIGH);
    delay(5);
    if (DownButtonPress()) {
      digitalWrite(dirPin,LOW);
      delay(5);
    if( isUp || isDown ){
      for(int x = 0; x < 5; x++) {
        digitalWrite(stepPin,HIGH);
        delayMicroseconds(2000);
        digitalWrite(stepPin,LOW);
    if (ResetButtonPress()) {
      count = 0;
      delay(5);
 bool UpButtonPress()
   bool isPress = false;
  if (UpbuttonState != lastUpbuttonState) {
    if (UpbuttonState == LOW) {
      bPress = true;
      isPress = true;
      Serial.println(++count);
      if (count >= 0) {
      digitalWrite(LATCH, LOW);                                 // Pull latch LOW to start sending data
      shiftOut(DATA, CLK, MSBFIRST, displayDigit[ count % 10]);
      shiftOut(DATA, CLK, MSBFIRST, displayDigit[ count / 10]); // Send the data
      shiftOut(DATA, CLK, MSBFIRST, 0);
      digitalWrite(LATCH, HIGH);                                // Pull latch HIGH to stop sending data
      else if (count < 0){
      shiftOut(DATA, CLK, MSBFIRST,displayDigit[abs(count % -10)]);
      shiftOut(DATA, CLK, MSBFIRST,displayDigit[abs(count / -10)]);
      Serial.println("Idle");
      isUp = true;
    delay(50);
  lastUpbuttonState = UpbuttonState;
  return isPress;
bool DownButtonPress()
  if (DownbuttonState != lastDownbuttonState) {
    if (DownbuttonState == LOW) {
      bPress = true;
      isPress = true;
      Serial.println(--count);
      if (count >= 0){
      isDown = true;
    delay(50);
  lastDownbuttonState = DownbuttonState;
  return isPress;
bool ResetButtonPress()
  if (ResetbuttonState != lastResetbuttonState) {
    if (ResetbuttonState == LOW) {
      bPress = true;
      isPress = true;
      Serial.println(count = count = 0);
      shiftOut(DATA, CLK, MSBFIRST,displayDigit[count]);        // Send the data
    delay(50);
  lastResetbuttonState = ResetbuttonState;
  return isPress;
Is this a program you wrote yourself?
...R
When it starts counting down do want to accept any button input to cancel the countdown or ignore all button inputs? You modification is easy if you want to ignore all button input while counting down, if not then it would be a little more work.
First, does that code work as written? If so then you probably need to add another conditional if statement for the third button, then work on the code to go into that statement. Start with small chunks and build on them.
