Stepper motor program with lcd and 4*4 Matrix Array/Matrix Keyboard 16 Key
Hello guys and girls
I have found this program on the web. That's exactly what I need for my workshop. I kept programmers name in the program out of respect for the time he spent writing it. But there have been some small errors in the program as I have directed. But there is an error which I can not figure out. I have sat for 3 nights and try all sorts of things, I hope one of you can see the problem and help me.
The program is designed to control a stepper motor. You can choose how many degrees it needs to rotate or whether to divide a circle.
You can find the original file here where you can also see a little youtube
further down in the code you can see I have marked line. If I remove it so I can upload code and my displaye works and I can choose "A" or "B" but after it freezes
A program for controlling a single stepper motor driving a rotary table.
Uses a 4x4 matrix keypad for entry of degrees and direction or number of divisions to move the table.
Serial I2C display, Pololu stepper driver.
#include <Wire.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'.','0','#','D'}
byte rowPINS[ROWS] = {11,10,9,8};
byte colPINS[COLS] = {7,6,5,4};
Keypad kpd = Keypad(makeKeymap(keys),rowPINS,colPINS, ROWS, COLS);
#define I2C_ADDR    0x27  // Define I2C Address where the PCF8574A is
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C	lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
 //setup vars
const int stp = 12;  //connect pin 12 to step
const int dir = 13;  // connect pin 13 to dir
const int StepsPerRotation = 400; //Set Steps per rotation of stepper
const int TableRatio = 72; //ratio of rotary table
const int Multiplier = (StepsPerRotation * TableRatio)/360;
const int stepdelay = 1;
float Degrees = 0;                //Degrees from Serial input
float ToMove = 0;                 //Steps to move
float Divisions;
float current = 0;
int Mode = 0;
 lcd.begin (20,4);                   // initialize the lcd
  pinMode(stp, OUTPUT);
  pinMode(dir, OUTPUT);
  // Print welcome message to the LCD.
  lcd.backlight();
  lcd.print("Rotary Table Control");
  lcd.setCursor(0,2);
  lcd.print("  CrankyTechGuy CNC");
  lcd.setCursor(0,3);
  lcd.print("   Copyright 2014");
  delay(2000);
lcd.begin (20,4);
  Mode = GetMode();
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile ("  jmp 0");
void rotation(float tm, int d)
  if(d == 0)
    digitalWrite(dir, LOW);
    digitalWrite(dir, HIGH);
  for(int i = 0; i < tm; i++)
    digitalWrite(stp, HIGH);
    delay(stepdelay);
    digitalWrite(stp, LOW);
    delay(stepdelay);
float GetNumber()
   float num = 0.00;
   float decimal = 0.00;
   float decnum = 0.00;
   int counter = 0;
   char key = kpd.getKey();
   lcd.setCursor(0,0);lcd.print("Enterees then");lcd.setCursor(0,3);lcd.print("    press [#].");
   lcd.setCursor(0,30);lcd.print("Reset");
   lcd.setCursor(8,2);
   bool decOffset = false;
   while(key != '#')
      switch (key)
         case NO_KEY:
         case '.':
           if(!decOffset)
             decOffset = true;
            lcd.print(key);
         case '0': case '1': case '2': case '3': case '4':
         case '5': case '6': case '7': case '8': case '9':
           if(!decOffset)
            num = num * 10 + (key - '0');
            lcd.print(key);
           else if((decOffset) && (counter <= 1))
            lcd.print(key);
            counter++;
         case 'D':
           software_Reset();
      decnum = num / pow(10, counter);
      key = kpd.getKey();
  return decnum;
float GetDivisions()
   float num = 0.00;
   lcd.clear();
   lcd.setCursor(0,0);lcd.print("Entersions then");lcd.setCursor(0,1);lcd.print("     press [#].");
   lcd.setCursor(8,2);
   while(key != '#')
      switch (key)
         case NO_KEY:
            lcd.print(key);
        case 'D':
          software_Reset();
      key = kpd.getKey();
     // num = 360/num;
  return num;
int GetMode()
  int mode = 0;
  lcd.setCursor(0,1);lcd.print("Selectode");
  lcd.setCursor(0,3);
  lcd.print("    DIV[A] DEG[B]");
  while(mode == 0)
  if(key == 'A')
    mode = 1;
  else if(key == 'B')
    mode = 2;
lcd.clear();
return mode;
  if(Mode == 1)
    Divisions = GetDivisions();
    Degrees = (360/Divisions);
  if(Mode == 2)
    Degrees = GetNumber();
    lcd.clear();
    lcd.setCursor(0,3);
    lcd.print("FWDEV[B] CAN[C]");
    while(key != 'C')
      lcd.setCursor(0,0);
      lcd.print("POS:");
      lcd.print(current);
      lcd.setCursor(0,1);
      lcd.print("DPM:");
      lcd.print(DegreesKey);                 <<<<<<<<<<<<<<<<<<   Don't know was wrong:-(
      if(key == 'A');
       if(current >= 360)
         current = (current + Degrees)-360;
       current = current + Degrees;
       ToMove = Degrees*Multiplier;
       lcd.setCursor(0,2);
       lcd.print("       Moving       ");
       rotation(ToMove,2);
       lcd.setCursor(0,2);lcd.print("                    ");
       lcd.setCursor(4,0);lcd.print("      ");
      if(key == 'B')
       if(current <= 0)
         current = 360+(current - Degrees);
       current = current - Degrees;
       lcd.setCursor(0,2);
       rotation(ToMove,0);
     lcd.clear();
](Arduino Sherline Rotary Table controller)
  while(key != 'C')
    lcd.setCursor(0,0);
    lcd.print("POS:");
    lcd.print(current);
    lcd.setCursor(0,1);
    lcd.print("DPM:");
    lcd.print(DegreesKey); //                <<<<<<<<<<<<<<<<<<   Don't know was wrong:-(
There is no variable called DegreesKey. There is a variable called Degrees.
The while loop cannot terminate once entered as nothing inside it can change the
value of key.
I don't think much of code which relies on a software reset. That should never be necessary.
You may find some useful stuff in stepper motor basics.
...R
Sorry to bring up an old thread. Did you ever get this working? It seems to be exactly what I need that's all.
