I am having difficulties programming what should be a simple sketch that gets my stepper motor to run at one step per second indefinitely at the press of a button and then stops at the press of another button. I am using the Bounce2.h and accelstepper.h libraries and have been unable to figure out how to do it. Any help would be greatly appreciated, and as for hardware I am using a NEMA 23 High Torque Stepper Motor connected through a M542T Motor Driver powered by a Switching Power Supply and running on an Arduino UNO.
Attatched find my code, and thank you so much for the help!
#include <Bounce2.h>
#include <LiquidCrystal.h>
#include <SoftwareSerial.h>
#include <AccelStepper.h>
AccelStepper stepper(1, 9, 8); // initiate stepper motor
//int buttonPresses = 0;
const byte ButtonPin = 10;
const byte LedPin = 13; // for debugging and visualization
Bounce button;
button.attach(ButtonPin);
pinMode(LedPin, OUTPUT);
stepper.setSpeed(1);
if (button.rose()) {
stepper.runSpeed();
digitalWrite(LedPin, HIGH);
// buttonPresses++; // count presses of button and print to monitor
// Serial.print("Number of Button ");
// Serial.print("Presses = ");
// Serial.println(buttonPresses);
else {
button.update();
digitalWrite(LedPin, LOW);
if (button.fell()) {
stepper.stop();
As of now, a button press runs the motor at 1 step/second, but a second press or any subsequent presses thereafter do nothing to stop the motor. Thanks so much!
use a boolean variable "buttonState" and in the setup() set it "LOW"
void loop():
continuously read the button
if the button was pressed and the current "buttonState" is "LOW" -> set buttonState "HIGH" and run the motor
if the button was pressed and the current "buttonState" is "HIGH" -> set buttonState "LOW" and stop the motor
So I have edited my program and added a boolean buttonState = LOW above the void setup() so it declares globally and then edited my void loop() to look like this
Just wanted to say thank you to RPT and Robin for the help. After using the advice, I notice how poor of a mistake I had made. I realize my fault in calling the runSpeed function within the if statement. I also needed to change button.fell() to button.rose() since button.fell() returns true when the button is released, so basically I was stopping the motor everytime I let go of the button. Here is the final, and working void loop() in case anyone runs into a similar problem in the future:
