Stepper motor RPM variation bluetooth
Hi everyone, I would like to comment on a rather peculiar situation, I am varying the RPM of a stepper motor nema 17 with driver a4988 in a cnc shield, and I am varying the rpm through an application in app inventor using bluetooth, with the application I vary well all speeds except when I put 50 rpm, the motor does not move, and it is strange because when I use the code without the use of bluetooth if I set rpm = 50; the motor does moves at that speed, at this point I would like ideas regarding this problem
#include <SoftwareSerial.h>
#include <AccelStepper.h>
// Definimos los pines utilizados
const int pinStep = 4;
const int pinDir = 7;
const int pinEnable = 8;
// Creamos un objeto de tipo AccelStepper
AccelStepper stepper = AccelStepper(1, pinStep, pinDir);
SoftwareSerial BTSerial(10, 11); // Creamos un objeto SoftwareSerial para la comunicación Bluetooth
int rpm = 0;
const int dir = -1; // 1 para CW, -1 para CCW
  // Configuramos los pines
  pinMode(pinEnable, OUTPUT);
  digitalWrite(pinEnable, LOW); // Habilitamos el driver
  // Configuramos el objeto AccelStepper
  stepper.setMaxSpeed(2000); // Velocidad máxima en RPM
  BTSerial.begin(38400); // Iniciamos la comunicación Bluetooth
char c;
  if(BTSerial.available()) {
    c = BTSerial.read();
    if (c == '1') {
      rpm = 50;
    if (c == '2') {
      rpm = 150;
    if (c == '3') {
      rpm = 250;
    if (c == '4') {
      rpm = 350;
    if (c == '5') {
      rpm = 450;
    if (c == '6') {
      rpm = 550;
       if (c == '7') {
      rpm = 0;
    stepper.setSpeed((dir * rpm / 60) * 200);
  stepper.runSpeed();
thank you
You running into integer truncation with rpm values below 60 with this equation. .setSpeed( ) takes a float for parameter so try
stepper.setSpeed((dir * (float) rpm / 60.0) * 200.0);
Yeah men now it works thank you
int rpm = 0;
  byte c;
  if (BTSerial.available() > 0) {
    c = BTSerial.parseInt();
    if (c == 7)rpm = 0;
    else rpm = -50 + c * 100;
    stepper.setSpeed(dir * rpm * 3 );
  stepper.runSpeed();
